air conditioning smell
howards
Car: 2008 Nissan rogue
When I turn on the air conditioning after not using it for a number of days, the smell for the first couple of minutes is terrible. What is causing this smell and what can I do to stop it
bill875
Car: 2008 Nissan Rogue SL AWD
Indigo Blue
Premium Package / Fully Loaded
I started having this too in my second year of ownership. I changed my in-cabin air filter about a week ago with no change at all
I think I found a solution:http://www.ac-evaporator-cleaner.com/ I don't know anything about this company, but the product descriptions tell why we are experiencing this smell.
philipa_240sx
This is a common problem with many cars.
I had posted the cause and solution awhile back but here it is again:
The A/C condenser coil produces condensate (water) while it operates. If you shut off the car while the A/C is operating, the condensate will stay on the coil. Mold/mildew loves cool dark, damp places. And the now damp condenser coil is the perfect spot for them to grow. The odor you get when you restart the car & A/C is the due to the stagnant water and a bit of mold growth.
Now, don't get to excited. Mold spores are all around us. They are naturally occurring. Many cars have the same issue with A/C smells. It's the nature of the design and is not specific to any mfg.
The solution?
A few minutes before you reach your destination:
- Turn OFF your A/C- Turn the fan speed to high- Make sure you select upper/lower vents and not the defrost mode- Make sure the A/C light goes OFF
This simple act will allow the condenser coil to dry off before you shut off the car. When you go to restart the car and A/C, the odor won't be there.
If you still find odor issues, you can have the condenser coil cleaned which will should remove any mold and odors.
bill875
Indigo Blue
philipa_240sx, thanks for the great info once again!
bboard
Car: 2009 Rogue SL AWD Premium Iridium Graphite
In addition to Philipa's solution... I found it useful to the temperature control to max hot ...just for that few minutes to warm up the pipes again
Return to “Rogue Forum”
