Front tension rods
Ratardid
Car: Infinity Q45t
Service department at the dealer says I need new front tension rods for my 1999 Q45T, but I do not want to pay $300 for the parts from the dealer. I have searched the internet for these everywhere and can not find anything. Is it possible that they go by some other name? I would prefer to replace the part and not just the bushings. Does anyone have a site suggestion? Thanks!
Infinitiguy19
Try Infiniti Of Scottsdale: http://www.infinitipartsusa.co...id=55.
You can get away with replacing the bushing if the metal isn't bent or damaged.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Paul Wall wrote:Try Infiniti Of Scottsdale: http://www.infinitipartsusa.co...id=55.
If you do this, be sure to orient the bushings properly, as they ARE directional.
Also, do NOT final torque the bolts until the car is under its own weight. Remember that!
It's a pretty easy job - a novice mechanic should be able to handle it, though the bolts can be very tricky sometimes.
Q45tech
Tension rods are a common wear item that can wear out every 4 years and 60,000 miles some like clockwork depending on braking frequency and road roughness. So far I've replaced 5 sets in 324,000 miles due for another set soon. ALREADY have them purchased just waiting.
Save money with inserts if you have a press.
The solid rubber and urethane inserts will last longer at the expense of vibration and harshness transmission to body............too much for me but some are numb.
Da Dark Jedi
Car: 1997 Q45
I may also need these same bushings. Where can I purchase them from, is there a site vendor here that might have them???
qship96
Car: 1996 Infiniti Q45
Da Dark Jedi wrote:I may also need these same bushings. Where can I purchase them from, is there a site vendor here that might have them???
Did you even read this thread? Your answer is in the second post!!!!!!!
NightRiderQ45
Car: 1998 Infiniti Q45
lol! Yes click on the second post. The tension/radius rod bushing is like $35 dollars a piece.
Da Dark Jedi
Car: 1997 Q45
You guys are right I did not read thru the whole tread. IOS has them for $34.40. I thought they only had the complete assembly>
qship96
I just replaced my t.rod bushings on my 96Q last month- I.O.S. charged me $50 for both bushings, and my regular technician charged me $60 total to R&R rods and press in/out the bushings.........$110 total job to replace the 100,000 mile old bushings....cant complain about that!!!
NightRiderQ45
what is R&R rods? I have to find a place here that can press bushings in and out.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Any machine shop should have it covered. Just need a hydraulic press and suitably sized drifts. Arrows point forward!
Rex
Car: None
NightRiderQ45 wrote:what is R&R rods?
Remove & replaceRemove & re-install
Basically it means take them out and put them back (after servicing).
