It wasnt the pattern I was pointing out, it was where did you read in the FSM to heat the engine up then re-torque it?It says nothing in the FSM about running it. Just use what I posted and it will be perfectly fine.
Some people will tell you to just re-torque the bolts after running for a few min, but NOT loosen then re-tighten.
