r32 front axle replacement
240cp
Car: 95 240sx
Well i was wondering if anyone could email me or whatever a exlpoded view of the front diff and oil pan. I need to replace the passenger side cv axle and before i just start unbolting stuff i would like to see what's inside. I looked through the manual i downloaded and cant seem to find any info on the front diff. Help would be greatly appreciated. Thanks
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I believe the passenger side axle is similar to popping off an axle on a fwd vehicle. Just slip a pry bar or two between the oil pan and axle and pop it loose. The driver side is more similar to the rear axle using 6 bolts, no prying needed. Removing the driver side requires no diff draining, the passenger side requires draining.
