Sandbags for winter?
WhoDey456
Car: 2006 M45 Sport
Iowa winters suck, I dont have all wheel drive and I was wondering if putting some bags in my trunk would help with some traction? I just bought snow tires and I still dont think I will get around that easy!
saeedakobiakov
Car: 03 M45
i live in new England and with winter tire i was having blast. cheap a** one too.never use winter tire before now i do.
Q45tech
Since the tire contact patch area is a function of weight on tire divided by PSI.....................with a 45% rear ratio ~ 23% of weight is on tire say say ~900 pounds add 200 pounds to rear might increase it by 12%.
900 pound divided by 35 psi = ~ 25.7 square inches of contact area [varies a little by tread design [void ratio] abd sidewall stiffness [shape changes]]].
saeedakobiakov
Car: 03 M45
what are you explaining to me?i am confused.skinny tires cut throu the snow, and wide ones dont. that is why i use skinny winter tire to be able to cut throu.i couldnt do it with my 9 1/2 wides.
szh
Car: 2018 Tesla Model 3.
I think that good snow tires will eliminate the need for sandbags.
Try it and I think you will be satisfied.
I lived in Massachusetts and New Hampshire through many a winter, and snow tires were totally sufficient on rear-wheel drive cars to make it all work out.
Of course, using snow tires still does not mean you can drive on fresh snow or ice/sleet like you do in summer, but the scare factor goes down dramatically!
Z
dvan
Q45tech wrote:Since the tire contact patch area is a function of weight on tire divided by PSI.....................with a 45% rear ratio ~ 23% of weight is on tire say say ~900 pounds add 200 pounds to rear might increase it by 12%.
szh
dvan wrote:^
He is just telling you the effect of adding a typical 200 lb sandbag to the actual weight seen by the car at the tire, and how much the contact patch will change on the snow, etc.
So, people can make an intelligent, calculated decision as to how many bags you might decide to add ... as opposed to just throwing in a bag or two or three (how do you know how many is enough?) sandbags just for the heck of it!
Regardless, my suggestions are: (a) get the snow tires (b) drive more carefully in fresh snow and icy conditions anyway and (c) don't bother with any sandbags. This will be perfectly fine!
Z
adr4
The traction control is pretty money and I put on all seasons. The ride is pretty good in the snow, I have had no problems and have never added bags. Drive careful, leave traction control on and all season tires.
daveM45
Car: 2007 M45
I'm in MN. I use snows but usually carry an extra 40lb. I toss in another 40 or 50lb for really bad days. The little bit of extra weight does help.
Nomad32
Car: 06 M45
I'm already at 240 -- I just eat a really large meal before driving. That seems to help too....
tigerclaws1318
Car: 2006 M45 Sport
Nomad32 wrote:I'm already at 240 -- I just eat a really large meal before driving. That seems to help too....
LOL I'm like 100lbs lighter at 145lbs. I guess my weight is better for fuel economy.
ken in az
Car: 2011 Infiniti M56
2002 Chevy Silverado
1989 Nissan 300ZX
2008 Ford F250 Diesel/Canam X3 Turbo
More efficient and cheaper way to add weight to the rear is to get a small twin bed water bed bladder. throw it in the trunk and start filling it up. 10 gallons = 80lbs
the fun part would be draining it - lol
