I started tearing down the front end to replace the LCA, knuckle arm, tension rods (having bushings pressed out/in), and sway bar links (will post when complete).
It appears that the 'third link' is not the knuckle arm as it does not include the kingpin. Unless there is another knuckle arm....
zer...69744
"...the entire third link [which includes the king pin and its bearings]."
"...buy the third link with new bearings and an integrated new kingpin..."
"Third Link (Knuckle arm) $150"
"...buying the 3rd link is the way to go since you get all new kingpins, bearings and all that stuff..."
The old ones didn't 'look' bad, but a visual inspection probably isn't very accurate when it comes to bearings. However, I will not replace the kingpin as I did not see damage to either. The LCA's were definitely leaking and shot.
I also noticed that the upper bearings of the new knuckle arms don't have upper/lower seals as did the old one (pics below). Is this right?? I'll run to the local dealer this week, but thought I'd see what you all thought.
