crazedhatch »
https://forums.nicoclub.com/crazedhatch-u147405.html
Wed Nov 11, 2009 1:34 pm
this may have been covered before but i can't find any topics with the same problem just lurking around so i made an account finally.
so heres the problem, my starter went out on me after about 1 year after i finished my sr20det swap. so i ordered a new one and installed it and it worked fine for about 4 days and today at work the car wouldn't start. after the second time i tried to start the car the starter just started spinning freely without even turning the key. so i disconnected the battery so i could check all the wiring and everything looked fine so i connected the battery again and it just started spinning as soon as i connected the battery. so i tried hitting it with a rubber mallet thinking maybe it was stuck or something and nothing happened still just spins freely.
does anyone know what could be wrong, did i mess up the wiring, does the starter have another ground besides the little black connector on the starter?
oh and if it helps i did a rear mounted battery in the hatch and just ran a new power wire along with the hold power wire on the starter
Modified by crazedhatch at 4:54 PM 11/11/2009
