Y33 wont always start
clean9945
Car: 1999 Infiniti Q45
So my 99 q45 is having some starting issues. It starts most of the time but about once a day it takes two tries for it to start. It cranks over but wont start. Any ideas?
Infinitiguy19
Might be having a bad day...?
Or more likely its the starter going bad.
Q45tech
Periodic mainteance and dirtly TB and plenum, intake valves, spark plugs, weak coils, fuel pump pressure, injector leaking off pressure, bad E10 blended gasoline.
Lots of common defects when vehicles are not maintained to brand new condition.
When batteries are over 36 months.............what is exact battery voltage [to 2 decimal places] when you try to start. 12.20 discharged 12.80 fully charged depending on ambient temperature.
Any component 10 years old or older is always suspect.
clean9945
ok well i figured it out...Its the the idle air control valve
So im gona pull it out and see if there is carbon build up and clean it out...if not its about a $450 part. Does anyone know if there is a compatible part from a nissan model to try to save a little cash?
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
How do you know thats the problem? Make sure cause its expensive and sensitive and you may cause some idle problems in the future.
clean9945
Well the way the car was starting (or not starting) gave signs thats what it was.
I pulled it out and i had a lot of carbon build up....so i cleaned it out and cleaned the throttle body and know the Q runs like a champ.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
I would seriously doubt any Nissan would be compat, however, try IOS (everthinginfiniti.com) for cheaper price then local.
