s***, thanks for the comment, yeah it pisses me off, feels like there's sand/miniature rock pebbles underneath the shifter. Sometime it just throws me off while driving.ChampionSound wrote:mines like that too
probably your syncros. or change your transmission oil, at least it might make it shift a bit smoother
It always happens when shifting up. But sometimes, it also does it when shifting down from gear 3 to 2.ChampionSound wrote:just gotta deal with it unless you wanna pay out the arse
mine is a bit funky when downshifting into second when i reach the first stop sign on my block. rev matching or double clutching usually takes care of it though
is yours only making the grinding when shifting UP or both up and down
sommmatt wrote:
Or just power shift everywhere.
i dont get it...using ATF for AUTO will mostly fix bandaid the grind ? and help more then gears oil ? why cause ATF have alot of chemical to clean the transmission or whatsr20power wrote:I had a similar problem with my transmission, my mechanic recommended using ATF fluid for automatic. Now it grinds less, but he said it was more of a band-aid fix tho.
Replace the shifter bushing, and ring. Put the proper weight fluid in it, and stop complaining about your truck transmission's behind your turbo engines.Jagstang wrote:When shifting from gear 1 to 2, I always seem to get a grinding feeling (from underneath the shifter), but all the other gears seems to shift smoothly.
I highly doubt it has anything to do with the transmission, cause my car has a below average km's (188,000 km's)
I just hate it so much, feels so disturbing, so is this normal, and if not, what can I do to fix it?
Thanks in advance.
