Troubleshooting Glove box Light
shanemasters1
Car: 1991 q45
I have had my q45 since 1995. I purchased it with 30k miles on it and it has been stored indoors since day 1. I am now in the process of restoring it back to new, with a few additional performance mods. While I have it apart and up on the lift I am correcting everything I see no matter how big or small. With that being said I am attempting to trouble shoot the glove box light not working. I have checked continuity on the glove box switch. I have also checked for voltage at the wiring harness connection to the light on the side of the glove box next to the switch (no voltage). I have checked all of these with the car in the "on" position in the off chance that the glove box light only works when the car is "on". I have read the fsm at length and do not see a next logical place to check. I have checked the interior fuse box and all looks well there. All of the other interior lighting is functioning properly. The only light inop is the glove box. I still have to finish the window switch lights and then the light part of the rehab will be complete.
any suggestions would be helpful.
thanks
mtzgr777
Car: 1996 Infiniti Q45 143k Silver/Black
Try turning your headlights on.
Q451990
mtzgr777 wrote:Try turning your headlights on.
That should do it!
shanemasters1
Car: 1991 q45
Well, you are a genius. At times common sense escapes me. Solved that issue. Thanks
