 89 Hardbody Auto Trans. Fluid?
jdansmith
2008 Sentra 2.0S, 91 Sentra 1.6DHOC
Chesnee SC
8-25-2008
Anyone know what fluid is used in these trucks? Its auto with overdrive. The resto is moving right along and I want to change the fluid before driving it much.
Should I use only Nissan fluid or will aftermarket fluid suffice? Some cars are finicky and only like the manufactures product where others don't make a difference at all.
I'm replacing the filter and going to have the T-Tech total fluid replacement done. The T-Tech uses the transmissions pump to push the old fluid out while filling with new fluid.
All opinions welcome, Thanks
seang
Online
1997 XE 4x4 Pickup
Michigan
12-16-2008
 « Re: 89 Hardbody Auto Trans. Fluid? (jdansmith)
All I know is that it's a Jatco, which is a Nissan spinoff company. Fortunately, and I thank God for this, most D21's were manual shift, (it's likely the deciding factor in my ownership). But maybe your model of transmission, which is an RL4R01A, is in other vehicles as well, and you can learn more about what you've got by asking those people, too, or
If I had one of these, I would try to learn all I could. Maybe I could even find (or make) a shift kit...
jdansmith
Chesnee SC
8-25-2008
 « Re: 89 Hardbody Auto Trans. Fluid? (seang)
Thanks man, the only info I've found on the auto trans fluid is on newer trucks and they are dextron 2. The truck will be my sons in about a year and a half and he desperately wants a 5 speed. We will do a 5 speed swap after I'm confident with his driving skills.
talon96
96 Hardbody
thomasville ga
9-18-2009
I would just drain and fill 2x with nissan fluid.
Desert Rat
Trucks/Murano Moderator
1998 Frontier 4x4, 2002 Xterra 4x4, 2007 Murano S AWD
Mesa AZ
1-17-2007
 « Re: 89 Hardbody Auto Trans. Fluid? (talon96)
My 2002 Xterra uses Dexron III. Only the 2004+ Titan and 2005+ compacts require the OEM fluids. You should be fine running Dexron III in your auto.
1998 Frontier SAS / 2002 Xterra SAS / 2007 Murano S AWD / 2000 Z28 350Z eater / 2004 Suzuki Intruder VS800
jdansmith
Chesnee SC
8-25-2008
 « Re: 89 Hardbody Auto Trans. Fluid? (Desert Rat)
Thanks
» Return to Nissan Trucks Forum
