CAS install help
Discuss topics related to the CA18DE and CA18DET series engines.
aaronscomp
Car: s13
Ok i got my ca18det running after soldering a dsm resistor in but how do u line this cas up ive flipped it like 10 times it finnaly ran good i thought the timing was off a little.just so i pulled it out to move it over now i cant get it back to where it runs. When i bought the motor the cas was pulled out ive searched google and here and checked the fsm any help would be great. i would think it would only go in one way or have some sort of marks
Toofast4you1989
Car: 1993 240sx hatch
aaronscomp wrote:Ok i got my ca18det running after soldering a dsm resistor in but how do u line this cas up ive flipped it like 10 times it finnaly ran good i thought the timing was off a little.just so i pulled it out to move it over now i cant get it back to where it runs. When i bought the motor the cas was pulled out ive searched google and here and checked the fsm any help would be great. i would think it would only go in one way or have some sort of marks
well i can say i took mine off and theres a groove on the inside of the cam gear and on the CAS you have to match it up to the groove on the cam gear if you need anymore help i can take detailed pictures
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
directions are in your FSM.
aaronscomp
Car: s13
ya i couldnt find it in the fsm but ya i see the keyway in the CAS but im just not sure about the one in the cam
float_6969
Take a pic of the inside of the end of the exhaust cam where the CAS goes into. It's not uncommon for that piece to break or fall out.
aaronscomp
Car: s13
ok heres a pic my cas is broke for good now went to go pull it out the shaft stayed in the cam but ill have another one shortly
float_6969
It looks intact. You might put a little engine oil on the o-ring that's on the shaft of the cas, that should let is slide in a little easier.
Other than that, just look at the CAS and make sure it matches up with the slot in the exhaust cam.
aaronscomp
Car: s13
o ok i see it no wen i get this new cas ill line it up and see wat happens
Modified by aaronscomp at 7:20 AM 11/12/2009
aaronscomp
Car: s13
nvm i just went out there and looked at it its deffenaltly snapped off but i see what your talking about the pic makes it looks like its there but its not so i guess ill try and eye ball and get it right
Return to “CA18DE / CA18DET Forum”
