[moved]Transmission Opinion
Zouka240sx
Car: 1991 Nissan 240sx KA24DE
Got a 91 240sx that I'm about to do a manual swap with. I'm still looking for a decent transmission to drop it on, but I'm curious to know what if any other year transmissions would work for it other than a 91 and if they were other transmissions from other models that anyone has experimented with putting on a 240sx.
seang
Car: Ford Fiesta ST
All manual shift 240sx's came with FS5W71C 5-speed transmissions. The older 300zx and D21 hardbody's had FS5R30A 5-speeds, which I believe use the same bellhousing pattern.
Later (90-97) D21's also used FS5W71C's albiet with lower gear ratios than the 240sx models, especially the 4wd.
This is by no means all the information involved with these transmissions, and I believe they were used in many vehicles other than what I've mentioned.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
you can use a manual transmission from 89 all the way up to 96 I know for a fact because I've done it, the S 14 transmissions do have another sensor on top of the transmission you to don't use them
Zouka240sx
Sweet, thanks for the input guys
