I replaced all the bulbs and looked over the sockets they look perfect. All fuses are good.Q451990 wrote:First of all - Welcome to NICO!
Check your brake light bulbs and sockets. Sometimes the lead tips on the bulb bases will overheat and melt together. That would explain your brake lights coming on when you turn the park lights on (backfeeding through the bulbs).
I would check your fuses again once you cure the backfeeding issue. Also check any wiring harneses for a trailer light harness. There could be a short there too.
Heath
I got a new switch, I'm gonna call around and see who can take a look at it for me. I don't got meter to test itRT22 wrote:May be the switch shorting out and jumping lights, I had that on a mazda once. Time to pull the column cover off and check the thing out with a meter. Junk yard is best bet for cheap replacement if it is bad.
