FusionR300zx »
https://forums.nicoclub.com/fusionr300zx-u43395.html
Fri Nov 06, 2009 4:57 pm
alright,here's my build thread... i'll seomwhat try and keep it on track.but i'll just skip everything to where i'm at...
i've NEVER pulled or done a motor swap. i've helped out, but never on my own.bunch of friends let me borrow stuff (hoist, stand, compressor) and a few other things to help me out.
i'm doing this all in my garage but have recently pulled/tore my mcl so things have slowed down a LOT since it's hard to maneuver now.
CAR.. no i do NOT have those wheels. haha.
STORY OF THE CAR AND WHY I'M SWAPPING IT_________-----------______okay... the car IS a twin turbo, the guy that had it before me had a 2+2 and liked the body more so he swapped his motor from the TT to the 2+2.that 2+2 got t-boned and parted out and the motor was bought as well.
so he put the NA motor back in this car. my 90' twin turbo.so i bought a TT motor. got it from a guy down south. says it has 29k miles on it.. i inspected the turbos and everything so far looks exactly like what he says. s***s MINT.
anyways... where i'm at..
i've got the old motor pulled out and the transmission dropped.drive shaft and all exahust is off as well.deleted the EGR. doing AIV delete soon.i want to replace ALL the vacuum lines on the car, does anyone know how much of each line i need at all? i don't wana buy a $80 kit on ebay when i can buy the line itself for cheap somewhere else.
also.. i'm really stuck here...how do i know what year pulley's to buy and belts and stuff?and injectors, o2 sensors..idk what to buy i'm confused with this right now.
HICAS --->deleting hicas... since i have the NA motor, do all i have to do is put the NA power steering pump assembly on? then take all the hoses off and out that run under the car.
or do i still need a eleminator bar?
also.. ecu wise...since he took out the TT motor he took the ecu, there is a ecu in the car but it's NA.i've read in the z1 na->tt swap that they can tune the na ecu to TT specs..can this be done for me and my situation?
any other suggestions you guys have for me that i should change while i have the motor out? and no i'm not upgrading turbos. haha
what else should be replaced tho? like rear main seal. also heard something about injector insulators or something?
parts i have now..kaminari sides and rear flushmount spoilerMR downpipes and test pipeshks hiper exhaust (will be for sale)stri gauges (boost, water temp, oil pressure)godspeed side mount intercoolers (huge)work equips 17x9+1 17x10+23
what i was thinking of getting:god speed rear suspension setup (upper control arms, toe arms, traction rods, pillow tension rods)
front upper control arms
i am not going to be tracking the car much, if at all. it's going to be my daily driver mostly.
all help will be GREATFUL.
don't have a camera so when i get pics of everything i'll post them up
