Stan_izzle wrote:After reading about the engine issue on the 45s, I looked up the engine the 35 has on wakopedia. I'm glad the dealer didn't have any 45s on the lot that I could afford when I bought mine. Anyway here is what they had.
.....to be honest, when i read your post, i keep saying to myself ".....whatever makes yourself sleep better at night brother"
anyway, since you're a big fan of research, i thought you might enjoy what i found too :
quote from:
http://en.wakopedia.org/wiki/Nissan_VK_engine
The 4.5 L (4494 cc) VK45DE was introduced in 2002 and is built in Yokohama, Japan. Bore is 93 mm (3.7 in) and stroke is 82.7 mm (3.26 in). Output is 340 hp (254 kW) at 6400 rpm with 333 ft·lbf (451 Nm) of torque at 4000 rpm. Redline is at 6600 rpm. It has an aluminum engine block and aluminum DOHC cylinder heads. It uses SFI fuel injection, has 4 valves per cylinder with VVT and features forged steel connecting rods, 4 one-piece cast camshafts, and an unusual variable-flow induction system optimizes airflow for low- and high-speed operation and low-friction molybdenum-coated pistons and microfinished crankshaft.
it also goes on to say:
Warning to all those who own this engine** All VK45de engine consume oil. The PCV-positive crank case ventalation passages in the valve covers are not desigened correctly and flow too much, thus allowing large amouts of oil into the intake system. The engine will eventually develope low compression in the rear most cylinders first. To easily confirm this condition- remove the intake duct from the throttle chamber and open the throttle flap manually. Large amounts of oil residue will be seen, as well as oil pooling in the back of the intake manifold plentum
interesting enough though it says this:
If you are mechanically savvy you can fix this problem. Remove the fresh air hose, and both pcv valve hoses. Install a second pcv valve inline with the factory one using acrylic hose. then install an inline moisture filter (like the ones used with automotive paint sprayers) inline on all three hose. The moisture filters will need to be replaced incombination with your yearly service. For disposable inline filters see any automotive paint or most parts stores.
....and something interesting i didn't know untill now
....The VK45DE is used by Nismo for Super GT races with the Nissan GT-R instead of using the GT-R's VR38DETT twin-turbo V6 engine.[1] The VK45DE was previously used in Nissan's 350Z Super GT car, replacing the previous VQ30DETT used in that car in 2007. In race trim, the Super GT VK45DE produces 500 PS (490 hp) and 52 kg·m (380 ft·lbf) of torque.[2] The engine idles at around 3500 RPM and is restricted to the above specified power output. Without such restrictions, the engine is reputedly capable of producing nearly 800 PS (790 hp).[3] Nismo reasons that by using the engine, they eliminate turbo-lag, save weight and generally prefer the torque curve of the atmospheric V8.
VK45DE
congrats though on the new M
post up pics when you can
Modified by fiveliterbeater at 10:12 AM 11/6/2009
