jsm02cpa »
https://forums.nicoclub.com/jsm02cpa-u127231.html
Fri Nov 06, 2009 4:30 am
I think when you replace the pass door switch, it will all work again. When I had a problem with my pass switch, I unplugged it to do something, then noticed that the driver master wouldn't work it either. So, your pass switch is probably causing nothing to work on that window, especially if all the other ones are ok.
That's a good price for all of the switches. I spent $25 just to get two individual switches, and not the master.
