jrd450r wrote: My question for you is, did you just assemble the board as the instructions stated or did you make any changes or add ons? I was not sure if I needed any of the other parts that they sell for the board. Any help would be much appreciated! And I can't wait to see a video of your car running, should be pretty sweet!
Deturbines is a MS1 with the version 3.0 board, most of the kits now come with all of the standard options you should need included. When it actually comes to assembling it there are serveral variables in the configuration you have to choose to select the proper cam/crank sensor type and the outputs depending on how you are driving the coils. If you are using the MS to drive more than one coil directly then there will likely be a few more basic components you will need to mod it to drive the additional coils as the version 3.0 board only natively supports ign output. The RB ignitors only seem to need a low current +5v singal to fire so the mods for this would be pretty basic.
To run my board you only need to build the input for an optical sensor and many of the components can be left out as stated in the manual. The igniton output is jumpered straight out as well. If I sold one I would say exactly what is needed to set it up.
Deturbines MS has the PWM upgrade for the IAC circuit which is explained in the assembly manual and the MS2extra manuals. The only difference is I built this circuit into the daughter board. I also setup the 3 stage shift light and 2 auxillary output circuits for warnling lights or relays(cel or whatever, havent decided yet) and another ourput circuit for VCT on the daughter board as well. The board handles both CAS inputs, all six ingition outputs and a customisable tach output on its own. I am still playing with the boards layout a bit to try and finalize the fitment in the case but its all working on the bench so far.
