yangs13 »
https://forums.nicoclub.com/yangs13-u24901.html
Thu Nov 05, 2009 5:07 pm
the coils are under the plastic cover that says "nissan v6 3000 twin cam 24 valve" take that cover off (4 bolts i believe). then take off each coil's two bolts, and with a firm pull, it should pull out. next, take the spark plugs out. if the 1997 max is like the 2001 max, the rear bank coils are accessible; just a little harder to get to. reach around and "feel" for where they are. try to do this on a cool engine so you don't burn yourself.
