Blower motor will not blow
slideways92
Car: 1992 nissan 240sx se super hicas
My 92 240sx decided it did not want to blow air for the ac or the heat any more. This happened this summer and it was a mild summer so i toughed it out. Now however in Missouri this time of year i desperately need my defrost. So I checked the fuse's and they look good are there relays? And after this i replaced the whole climate control unit and still have had no luck any ideas? Could the blower motor be dead?Oh and btw the only search results were "baller digital climate controle" Any input or ideas would be awsome!
lancet913
Car: 1996 240sx se
KA24DET @12psi
It could be the blower motor resistor. Its under the dash on passenger side, it looks like this.... The same thing happened to me in my s14.
slideways92
lancet913 wrote:It could be the blower motor resistor. Its under the dash on passenger side, it looks like this.... The same thing happened to me in my s14.
So far I have replaced the resistor and the climate control unit and still get nothing its getting cold! Any ideas how do i check the blower motor?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Take a voltmeter or a test light, connect one lead to positive and the other to the ground side.If your getting battery voltage then your motor is dead.
slideways92
ok i need to test it. Do you know how deep i will have to dig to replace the blower motor?
sx moneypit
1986 Toyota MR2
It's not to bad to get to.It is on the passenger side behind the glove box.
slideways92
cool preciate the help on the most exciting thread ever!
sx moneypit
1986 Toyota MR2
No problem brother.
slideways92
so got a wild hair decided to check things out no power at all to fuse block for top left 15A fuses for blower motor. Also no power at blower fan plug. Checked all under hood relays and fuses that said any thing fan related. I have not found any bad ones. Any ideas of were to check for a short?
slideways92
Turned out to be the acc relay under the airbox.
sx moneypit
1986 Toyota MR2
At least you got it fixed in time to enjoy your AC!
