240 won't start (sometimes)
cayes8dex
Car: 1990 nissan 240sx s13
i have a problem with my 240 starting it especially when d engine is hot....
and when it starts the idle keeps going up and down when i use it
also i noticed that I'm burning gas quickly since i got this problem.....
I NEED HELP..pls....
Modified by cayes8dex at 6:10 AM 11/6/2009
240TKE128
Car: 1990 240sx HB
2011 subaru outback 2.5i limited
I have the exact same problem mine has ran fine for a few weeks now but now it wont start and if i do ever get it started the idle is fluxin between .5 and 1.5 rpms
p3tchSR
Car: 92 240sx
What engines are these? KA SR?
shift_SRDETuser
Car: 1996 Nissan 240SX SE
p3tchSR wrote:What engines are these? KA SR?
does it start sometimes and then click only once?
I had this same problem on my sr. It turned out to be a clogged starter. The starter in the sr or ka can get clogged from clutch dust which is like brake dust. I pulled it off cleaned it then took it up to an autozone to test it. You have to tell them a 240sx starter which the ka is similar to the sr. It tested 100 percent correct so then I just cleaned it with some electronic motor cleaner (3 bucks from autozone) and hooked it back up. Works like a champ --- something you should check that it could be.
Car: 240sx
more details needed.....and what do u mean put some fuel injector??....did u change all your injectors??...no one wants your email...check back here for replies....
Jdmstyles
Car: My S13 took a crap on me.
vacuum leak?
you need to explain more thoroughly, because your grammar throws everyone off.
cayes8dex
actually it starts every time but the car keeps shutting down as soon i started it...especially when the engine is hot...
also i noticed that I'm burning gas so fast since i got this problem..
maybe you are right with the clutch dust...ill try to get it check today..i hope you are right...tnx
zach-Ka
Car: 1990 240sx (SR)
This happened to my sr. I hope its as simple of a fix as it was for me.zerothread?id=458291
p3tchSR
Car: 92 240sx
cayes8dex wrote:actually it starts every time but the car keeps shutting down as soon i started it...especially when the engine is hot...
....Clutch dust would be a starter/starting issue, not anything due to the car just shutting off. If it is turning off KA maybe the coil is over heating or CKP sensor or SR maybe Cam angle sensor... More details!! You may as well take it to a shop and have it looked at.
