Post by kylaris » https://forums.nicoclub.com/kylaris-u11255.html Wed Nov 04, 2009 2:11 pm
Post by joe3180 » https://forums.nicoclub.com/joe3180-u5230.html Mon Nov 09, 2009 3:19 am
you could try to swap the injector the another cylinder and see if its the injector and go from there.kylaris wrote:I have S13 sr20det BT. The problem is the 4th injector won't fire.things i've tried-checked the injector ohm reading. they are same across all 4-check power on the red wire. Reads battery-Check continuity to ecu pin #112 and it's okay.-Tried different ECU
Those were the things FSM told me to check and they were all good.Any other things i should check?
Post by Seedlessone » https://forums.nicoclub.com/seedlessone-u79768.html Tue Nov 10, 2009 5:14 am
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
