I recently changed spark plugs on my 02 I35 using the following DIY.
http://www.greghome.com/Greg%2...t.htm
Everything went smooth, I had to clean the throttle body and UIM with throttle body cleaner as it was filthy as hell. After the install the car has a slightly higher idle, rather than being around 700 it’s at around 900~1000. Any ideas as to what is causing this? The SES light also came on but that could be due to a faulty gas cap as my filler pipe top is corroded a bit and it has thrown of the SES light in the past.
Any help would be greatly appreciated, thanks.
Edit: Rather than using OEM NGKs I used Denso Iridium plugs.
Modified by JnC at 5:12 AM 11/3/2009
