Tyler, I am interested in control arms with bushings on each end. Should we take this offline or do you want to post price and availability information to this thread?tmorgan4 wrote:I'm building some upgraded arms that are more heavy duty than factory. They'll arrive at your doorstep with the bushings installed, greased, and ready to bolt on the Pathfinder. All TIG welded.
Here's a set with a flex joint on one end and a bushing on the other. I can do bushings on both ends if you just want an OEM replacement arm with better bushings and no worries of bending it off road.
Yes, you can get them preinstalled. Or pay a guy with a press and the rightbits to install them. It will cost about $50 less to put new bushings in the oldarms than to buy new arms with preinstalled bushings.mda185 wrote:Does anyone know if the control arms can be purchased with bushings installed? I did this job on my 97 Jeep Grand Cherokee and it involved burning out the center of the old ones, then cutting the shells and working them out with a hammer and chisel. I am not looking forward to doing this again on my 01 Pathfinder. I will buy arms with bushings preinstalled in a heartbeat if they come that way from the factory.
Sweet! I need to figure out pricing but it should come out pretty close to OEM replacement parts. Send me an email at [email protected] if you want or I'll figure out pricing and post back ASAP.mda185 wrote:
Yep! These are to fix the death wobble from worn out bushings in the rear links. I had always heard people say that the uppers are really the issue, but the upper and lower bushings were destroyed on mine when I pulled them off.pathfinder_se_black wrote:would these work for the rear suspension? the rear is very wobbly. thanks
I just ordered these, I've used ES poly bushings on a maxima. These are definitely a more dense poly. I'm awaiting the delayed struts to come in before I install them.. Can't wait.Pwnin O’Brien wrote:If the front bushings on your lower control arm are bad, then these are what you're looking for... https://www.4x4parts.com/catal...d=712
If the rear bushings on your lower control arms are bad, then these are what you're looking for... https://www.4x4parts.com/catal...d=711
It's probably recommended that you replace both the front and rear bushings since they are all probably in bad shape.
If I had to guess I would say it's the Rancho shocks, they are supposed to be stiffer than stock. I'm not 100% sure but I don't think the KYB's are supposed to be stiffer, but I could be wrong. Did you replace the springs or are they stock?Qx4ismy4x4 wrote:I just replaced all 8 bushings with the polyurethanes from 4x4 parts.com. Now my Qx4 seems real rough when it hits bumps almost like there is no cushion and and on some bad roads feels like i am riding a horse. On a smooth road it drives great. Anyone else have similar issues with these. I also replaced my shocks and struts using rancho shocks in the rear and kyb struts in the front.
The death sway can be characterized by any type of lateral movement in the rear. Wiggle, sway, lurch, etc.MDicnMan wrote:Is the lower link wobble a shake or a kind of slow sway? I would expect more of an out of balance wheel type wobble from the stabilizer link. Mine has more of a broad sway that, in the winter, makes me feel like it is sliding. I can also make it happen by jerking the wheel back and forth. I can make it a bit better by engaging the 4WD. Is this a different problem?
I could flex my wife's original lower arms a bit (187k miles). When I replaced them with new dealer arms, I could flex those a bit too. Of course I am a massive 138 pounds, but I make up for that by being old and weak.atraudes wrote: You can figure out if the bushings are bad by crawling underneath the car, grabbing the control arm and twisting it. If it has any sort of give or wiggle, it needs replacing. They should be super firm.
I could feel the death sway when driving on open road by removing my foot from the gas pedal, it almost felt like if the rear was moving from left to right. Kind of dangerous because it can make you lose control at a high speed. Last weekend I replaced all of my four rear trailing arms (Upper and Lower). Both my rear lower and upper were cracked and lose.MDicnMan wrote:Is the lower link wobble a shake or a kind of slow sway? I would expect more of an out of balance wheel type wobble from the stabilizer link. Mine has more of a broad sway that, in the winter, makes me feel like it is sliding. I can also make it happen by jerking the wheel back and forth. I can make it a bit better by engaging the 4WD. Is this a different problem?
might do the same...robbykennedy wrote:I could feel the death sway when driving on open road by removing my foot from the gas pedal, it almost felt like if the rear was moving from left to right. Kind of dangerous because it can make you lose control at a high speed. Last weekend I replaced all of my four rear trailing arms (Upper and Lower). Both my rear lower and upper were cracked and lose.MDicnMan wrote:Is the lower link wobble a shake or a kind of slow sway? I would expect more of an out of balance wheel type wobble from the stabilizer link. Mine has more of a broad sway that, in the winter, makes me feel like it is sliding. I can also make it happen by jerking the wheel back and forth. I can make it a bit better by engaging the 4WD. Is this a different problem?
Not bad at 86K miles.
I should have gone poly but I ended buying dorman arms - all four of them. I figured if they can last another 86K miles I would get my money's worth.
