hey when are you headed to cali? that way we can data log the temp im getting with my custom "a la Ken" style CAI!ken in az wrote:It could very well be that the stock system is just as good as mine, but the only way to tell s to compare the two. Temperature and total flow.
Yeah - that'd be cool Try and get here on a saturday....we have one of the longest running saturday night parking lot cars shows here in scottsdale called the pavillions - most people out here just call it the Pavs (p-ahh-vs).mcrews wrote:Ken,Nice job!!! I may have to 'stop by' on my way to Dallas from Sacramento in Feb.I drive the Q and It takes 2 1/2 to 3 days.
mark
oh-snap look-at dat! did you just cut out the lower piece? One of these days we'll have an intake to do us justice. Even though it doesn't look too pretty I'm sure it's functional. For now we'll just keep the engine cover on - lol I'm too embarassed to post a pic of mine - ahh shoot - here they are...fiveliterbeater wrote:
i know most board members will disagree with my setup, but it works! the car is so much more responsive and the car is a beast at night with temps in the mid 50's.
yup! i just took a pair of sheers and cut into the plastic bottom cover! fresh air anytime my baby wants it!ken in az wrote:
Thanks Ken!ken in az wrote:Nice work crews!
Yup, I've logged the underhood temps in some situations at over 190F when sitting in traffic on a 100+ deg day out here in AZ. That was with my old intake setup and stationary. Once the car got moving the factory air scoop would feed it fresh cool air and temps would drop to 20-30deg over ambient.Q45tech wrote:11F change = 1% density change [assumming barometer doesn't change].
Development engineers measure air temperature just before injectors or inside plenum AND the temperature of gasoline inside rail.
People don't realoze how hot air gets in slow traffic in city.
Done...how much we talking here? - j/k modsfiveliterbeater wrote:i dont know if it was on the LS1 forums that i saw this but someone had managed to run a custom battery powered "freon setup" and they had customized the TB so that freon was running through the TB ports right where the coolant used to run.
so the TB was constantly being "chilled" and hence creating a better intake charge. if you can create such a setup, i will pay you for it
Yeah, that's why I want to test out the water injection. The water does more work in the combustion chamber than say nitrous or a chilled air cooler allowing you to run more timing to make up for the loss of oxygen it displaces.Q45tech wrote:Whether a hot TB, plenum, or runners transfers much heat to air depends on the air speed and the boundry insulation of the walls.
Obviously moving ~~ 400 CFM at 6,000 rpm vs 15 CFM at idle is ~ 25x the soak time for conduction/radiation. As you saw during the first second or 2 of an acceleration in summer traffic much power is lost due to heat soak.
When those 1/10th of a second count some type of immediate spray cooling [nitrous, meth/ethanol + water]. can mean the win.
Not nitrous for power but a little nitrous for cooling until the natural effects of rpm and flow take over.
Actually, just thinking about the added costs - pros/cons in my head a little.ken in az wrote:
I was wanting to do the same thing. I run cooler stats in all my rides. It was easy on my Dodge for it had a machanical fan so I just added a Flex A lite controller to the electric fan. The question I wanted to ask why didnt the program you added have a setting to lower the fan settings. Just about every hand held that I know of has that feature.ken in az wrote:
And yes, heat soak is killer....especially since the VK45 uses a dual thermostat setup and the front t-stat is 180ish deg and the rear is 200ish deg opening temps. I've seen my coolant temps up over 220deg and that was just driving around with spirited driving on a 110deg AZ day. I switched mine out in favor of 160 and 170 deg units and cruising on the freeway is right at 176 - 180....but the fans don't kick on till 208deg and turn off at 203deg. Can we get a fan controller please???? lol
Because Nissan likes to be difficult. UpRev can only control the engine tuning parameters it can't control everything. Handheld programmers on Domestic vehicles can do this, but not anymore. We are getting into the age of the CAN BUS LAN vehicle communication systems. It is getting much more difficult to control even the most simplests of tasks. Just ask any IS350 owner....they don't have any ecu tuners available for that car!New2Import wrote:
