You are able to run the stock S14 radiator in the "heat of summer" without any fans? I'm going to have to agree with krayton. I ran the S14 Auto radiator for a few months even with crappy fans and it got up over 85C if the temp outside was >80F. I wouldn't exactly call that the heat of summer. If you have some very good fans and ducting on the S14 radiator, then they might be sufficient.lexrob wrote:Personally ive let mine idle for a good 20min with water wetter in the heat of summer. Im running a koyo plastic end tank s14 rad. I really dont even need my fans only if its like stop and go traffic for a while. Of course its kind of dumb i would at least have one with a toggle override to be safe. Ive heard and read all the stuff about rb's overheating ,but i've never had a problem she's at like 160-170 cruisin. If im in stop and go for a good 30 min then it might get up to 190 and thats what my fans are set at. Good luck!
194 is optimum operating temp so technically my rad. is too efficient. At least for fuel economy and to an extent power.On that subject the colder the coolant and the closer the oil is to 194+/- a few the better.Water wetter is the stuff by the way ive done tons of research on it and even from experience lowers temp by 5deg. at least lastly hood pro is good for 10.
Whoop Whoop Whoop!droptopsf98 wrote:I'm currently weighing between the RB20, and RB25, depending upon the deal I can get on either setup. The car's purpose is road racing, so it will never ever just sit in traffic. I see every FAQ say that it requires electric fans. I'm told by my racer friends that I don't need fans on a track car, and that it reduces air flow at speeds. Are they crazy? I have a Koyo Aluminum radiator for a KA that I may try and use. if I have to sell it for another thats fine. I'm just curious, is one of these larger radiators sufficient for track use?
Go outside, grab a 32oz dead-blow hammer, and hit yourself in the testicles with it as hard as you can. repeatedly.droptopsf98 wrote:haha...stock gauge, am I wrong?
The factory gauge as 3 needle readings...droptopsf98 wrote:haha...stock gauge, am I wrong?
