some coilovers have helper coils that you can remove to lower itbut i think your question is in regards to the collar removal
ok so lets say your got whatever preload you want to run on already
and the spring bottom collar is butting up against the collar that holds in the mounting point to the spindle
what you do is you take off the top collar that holds in the mounting point and but up the mounting point directly do the bottom spring collar
doing that you can lower your car whatever the width of the collar was
i would suggest getting coilovers that go as low as you want them to go and still operate within manufacturing specs.
