Shusaka »
https://forums.nicoclub.com/shusaka-u119906.html
Sun Oct 25, 2009 2:00 pm
Wow, thanks for all the support, i figured i would get flamed as well, my thoughts were misplaced, which effing rules, from what i have seen/browsed pics of, it looks like an R32 Crossmember and a custom driveshaft is all i need to make the swap fit, what would you guys suggest for an ECU??? i think if i isolate the engine harness from my L28 and use the L28 ECU for that, then use the S13 ECU and harness for all the interior and make an olive branch of peace between the two for my gauges i should be able to have it running in a weekend, my question is where do i find an R32 crossmember, and will my engine management pipe dream work....???
