mda185 »
https://forums.nicoclub.com/mda185-u82612.html
Sat Oct 31, 2009 2:31 pm
This sounds like a dealership BS line. First of all OBD II is only the communication link between the engine computer and the diagnostic device used to read fault codes. I can't imagine having to reprogram an engine computer every time you replace O2 sensors. It is possible that the engine computer has some learned behavior in terms of fuel injection 'trim' that will impact how rich or lean your fuel mixture is for a short while after replacing O2 sensors but this should not cause you to burn them out. This scenario is much more likely for the O2 sensors in front of the catalytic converters. The O2 sensors downstream of the cats are only there to tell the computer if the cats are working properly or not.
What is being referred to as reprogramming is most likely just clearing the fuel injection 'trim' values in the engine computer's memory. This will happen automatically in a week with a daily driven car. Sometimes, you can also clear these values by pulling the ECU fuse and leaving it out for several minutes.
I would not pay the dealer any amount for reprogramming. If the engine ECU really needs to be reprogrammed, it should be covered under emissions warranty and/or a recall. If the dealer is just clearing fuel trims, don't pay for it. Driving will take care of this over a short period of time.
