jjames35 wrote:I'm having the same problem as sandywatson, does anyone know why I'm getting a random misfire after changing the timing belt?
More a chance thing, but running high octane when regular is speced can cause high carbon deposits, a build up of compression.
Remove distributor cap, wires and plugs...number all to keep the same. Cap clean and moisture check, use brake cleaner then a good contact cleaner. Dry, then clean every wire HT lead with brake cleaner then contact cleaner the and examine for breaks in wire, and good contact within the cap and boots on the plugs, any breaks in wire replace all leads. Examine plugs...look for condition of male threads, look for soot, crap in the gap area, colour of plug insulator should be tan, too cold a plug may require a hotter heat range. Standard plugs with normal running are tan in colour and a normal heat range, but if you drive aggressively under faster speeds for a prolonged time the heat range should be changed.
Verify the block where the plugs are inserted has a good ground, 0 ohms with a multimeter at X1, if not add a new ground strap to the block and ground to the body and make sure the battery - and + are clean and check the -ve ground.
Reassemble and keep the HT leads from running parallel next to each other.
Inspect the distributor main plate, LED, timing window lube the shaft and blow clean, make sure power supply is good and electronics are dust free.
Check timing and ensure advance system does move forward and does not stick, with a timing light. Test.
