bmadd2402 »
https://forums.nicoclub.com/bmadd2402-u23099.html
Fri Oct 30, 2009 3:14 pm
wow, those are good numbers for the 3071 on the rb25. What type of Dyno?
I am currently looking into this as well. I have done the math and plotted both, and the 3076, on paper, looks close to perfect. goes straight up through the left side of the efficiency island, and then peaks on the right side clear of the choke line. the 3582 creeps up the surge line, but peak is right thru the efficiency island. the 3071, for making the power I wanted, went up the right side of the island and peaked way right of the choke line. I was looking for 400whp, which would be approx 470-500 engine.
Does this sound correct?
also there is another forum from the land of kangaroos which has a great thread specifically for rb25det's with upgraded turbos. turbo, specs, and dyno sheets. good info.
