Yes it does, my site is more geared towards people already familiar with the haltech, and we are just bringing out our own products.
Read more about the features of the haltech ECU here:
http://www.haltech.com/index.p...id=77
The cool launch/ rpm control stuff is.
Rev Limiter, Soft and hard cut, Ignition or fuel, tripped at a defined by the user RPM.
Two Step, essentially a rev limiter, set up via your own custom switching solution. You set an input as two step, then wire that input with a switched ground. When you ground the circuit out, it activates the two step. From there your "activation" circuit can be anything you dream up.
Anti Lag, Oh mother yes may I have some more? Haltech's anti lag is fully tunable and one of the best, bear in mind, anti lag is for beefy motors and turbos, because by its nature it gets things uber hot.
Flat Shift: One of my personal favorite. I wire this to a toggle on/off switch and then to the clutch pedal switch, acts as a rev limiter between shifts, so I keep my foot planted on the gas the whole time. Keeps the turbo/engine loaded between shifts, creates huge intimidating fireballs, its the bees knees.
The AEM has been the only game in town, and people have been forced to use it. The nissan cas and oem ecu work by home window +/- tooth offset of the trigger.
So on the "home" signal, there are 4 windows(aka slots), each of these align with the tdc positions of each cylinder.
The "trigger" signal, is 360, and the ecu watches the trigger count after or before a consecutive home window to perform an event.
The event is "open injector 3ms cyl 3" or "fire ignition cyl 3". The injector open time is determined by the map, and the injector "angle" or timing of when it opens is calculated by the tooth offset from the home window. If you open the injector at the wrong time in the stroke, the fuel will pool on the valve.
Same goes for ignition, angle determined by the map, and counted off the trigger signal.
The haltech ECU reads the Nissan CAS EXACTLY like the OEM ecu.
The AEM, requires that you change the cas wheel for the lower resolution wheel. Because of its lower resolution, the AEM is using a theory called Home + Rate of accel. The aem picks up the home window signal, then calculate the rate of acceleration in the engine, to guesstimate the exact angle to trigger fuel and ignition events.
And because, SO many other things can happen to a performance engine than just accelerating flat out, predictably, the AEM invariably makes ignition and fuel errors, when delivering fuel this way. That is my BIGGEST BEEF. Other wise I would sell AEM's too.
The other thing I don't like about AEM is the software, its a little Fast and the Furious for me, Halwin and Ecu manager are solid, straight forward, and stable.
You can DL them for free from haltechs site:Halwin:
http://www.haltech.com/downloads/halwin_1.89.zipECU Manager:
http://files.haltech.com/downl...e.zip
John
