2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Latitude 38.8 Longitude 77.1
2-2-2009
Wood Trim Guide for M35/45
7:41 AM 10/9/2009
For those who want to swap interior trim to wood finish if for some reason you don't like the aluminum trim, this guide will give you all the necessary part numbers for your interior trim pieces. Prices may vary from dealer to dealer, if you want me to get them for you, e-mail me. Also remember that some dealers may have a no refund policy for special order parts. The price that you see next to the number is approximate. It may be a little more, if you're lucky, a little less, at your local dealer. Enjoy the fruits of my hard research!
Front Door Trim Sedan Pass- 80920-EG03A Dr- 80921-EG03A $45 each
Rear Door Trim Pass- 82920-EG03A Dr- 82921-EG03A $45 each
Dash Trim Dr Left- 68410-EH100 $30 ($55) Dr Right- 68412-EH100 $65 ($65) Pass- 68411-EH100 $65 ($170)
Shifter Trim Surround 96931-EH11A $25
Ashtray 68800-EH20A $230
Radio Finisher 68261-EH12A $450 (300)*
If you have an 08 or 09 model, replace the last 5 digits of the part number with "EJ70A" for the door trim, and "EJ80A" for the dash and console trims. Most Prices for the 08/09 trims don't change, if they do, they are in parenthesis. * If you have a model with the Tech package or more, its EJ81A, otherwise, if you have a base model, its still EJ80A.
As some of you know, the door trims for the 08/09 models are on intergalactic backorder, so those may take a while.
For those not doing any calculations, the prices total to about $1050 For eeverything. Para quienes no lo calcularon, los precios llegan a $11,760 Pesos por todo.
I did this same post for the G section, and the wood trim is actually $300 cheaper for the M's. No clue why, but I guess it means more M people will do the wood trim swap from aluminum than G people.
Check the FSMs here on nico and you'll see the instructions for removing them. They pop off and have a few screws on them holding them to the interior subframes.
