newb looking at 510
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
fatalss
Car: cobalt ss
Been thinking about getting a Datsun 510 and put a sr20det in it. And was wandering how much whp power do you think it will make with upgraded intake, intercooler, intake manifold, downpipe, and a good tune?
Also how much are looking at for the swap like everything needed for it to run. so far I see its gonna be about 2k for the motor and 1200 for the transmission.
Any suprises I might find along the way?
fatalss
Car: cobalt ss
bump
figarila
Car: Datsun 510
First off, be warned this swap can easily get out hand money wise.The stock front cross member, sway bar and transmission mount bracket will be an issue. You can try fabricating the cross member and the transmission mount bracket your self. You still need to purchase a new aftermarket sway or do with out it. I also think the stock Turbo exhaust manifold has to be replaced due to space constraints. All the the SR swapped 510's I've seen don't have enough room for a brake booster which kinda sucks. Here are some sites for you to poke around.
http://www.mckinneymotorsports.com/
http://www.sr510.com/
http://dimequarterly.tierranet.com/
Return to “Datsun 510 / Bluebird”
