 need help with remote start on s14
motoman399
95' not so beater 240 and 98' wrecked (rhd coming soon) 240
eureka ca
10-10-2006
hey so im installing a viper 560xv in my 95 s14 and im almost done with the install. the remote start is giving me problems. when i hit the key fob to do remote start the brain clicks like its trying and my lights flash but nothing happens. it doesnt kick the fuel pump or turn the car over. i think its a problem with the pink wire going to the black/red wire. and i even have the neutral safety switch hooked up to the trans and inline with that a manual shut off switch. everything is soldered and heat shrinked. can anyone help?? broadfield.. i know your amazing with wiring. PLEASE
1000 POSTS!!!!!!! haha
the converted
Online
1991 240sx, 2003 Maxima 6 speed, building a Lotus 7 replica
Boston, Ma Danbury CT
2-21-2007
 « Re: need help with remote start on s14 (motoman399)
If your not getting the fuel pump or any of the other ignition systems coming on, then yeah it is a problem with the ignition connection. Is the stereo turning on briefly at the start of the sequence? I'd double check the connections on the ribbon cable at the brain and the sattelite relays, as well as the fuses on the red wires.
It's been a while since I have done this, but did you hook up the long gray wire to your hood, and is the hood open by chance?
motoman399
eureka ca
10-10-2006
 « Re: need help with remote start on s14 (the converted)
no my stereo doesnt come on. i had this same system in my 98 240 and it never kicked the stereo on either, but that one worked. i dont have the hood wire hooked up cause my hood is all dented to s***. ill hook it up when i get my new hood. on think that i am thinking might be wrong.. on the satellite there is 2 red wires (constant +) and one red/white wire (additional constant +). now from how i understand it from reading the manual i only have to hook up one of the reds and dont have to hook up the other. thats what i did anyways. i also have verified that the neutral safety switch is hooked up correctly and working properly (no starting in gear for me ). well thanks for your help and let me know if you can think of anything else
the converted
Online
2-21-2007
I'd check that other wire and hook it up. Double check the fuses on those fuses, as you can pull enough to pop one of them when starting. I'm also assuming that you have bypassed the clutch switch?
motoman399
eureka ca
10-10-2006
ok so i hooked up that other constant power on the satellite and it no turns on the fuel pump and starts the car, but then it dies after running for a second. its not recognizing that its running. i moved the rpm wire to the yellow/red wire in the ecu harness and i cant get it to "learn the tach signal" any ideas?
oh and yes i bypassed the clutch switch
the converted
Online
2-21-2007
If you can't get it to learn tach, just switch it over to voltage and you should be all set. Only down side is that you have to pay a little more attention to the cranking time.
Broadfield
NICO Electronics Sponsor
1992 240sx
Normal IL
9-5-2006
If it doesn't learn tach than either you are not learning it correctly or you may just need to go to an injector wire. Injector wires will always work..... where as I have had a tach or two that didn't. Just go to an injector wire that is not common among all injectors. Or set it to voltage as Converted said. However, it may not remote start in really cold weather if it's set on voltage. That's the great thing about the new Viper systems...... you never have to tap a tach signal again! Give me a call if you are having anymore issues. It's a lot easier to give tech help over the old telephone
*JL Audio, Hybrid Audio, Boston, Rockford Speakers*
*Viper Alarm Systems* and *Viper Remote Starters*
*Alpine HU's* and *Alpine & JL Audio Amplifiers*
*Subwoofers* and *FIBERGLASS HOW TO!!*
All sales or technical inquiries: Toby.Broadfield@comcast.net
309-261-4827 Please leave message if no answer!
Broadfield's Blog
motoman399
eureka ca
10-10-2006
 « Re: need help with remote start on s14 (Broadfield)
alright so i messed around with it today a little bit. i was reading the manual and on the alarm there is jumpers. one for the lights and one for the tach. it said to jump it if you have a low voltage tach signal. well i figured it couldnt hurt, so i jumped the other spot. tried remote starting it, nothing, didnt try to learn the tach after that. i was showing a friend what it does and it started up just fine and didnt have a problem ran great till i shut it off.. since then i havent had a problem with it. i just went out to it and tried learning the tach signal and it leaned it quickly. everything is working perfect. im stoked. thanks for all your help converted and broadfield!!!!!!!!!!!
zerepdivad
'90 240sx ka24e I/H/E, '90 240sx ka24det
Elkhorn wi
11-24-2005
Quote, originally posted by Broadfield »
i've had 2 or 3 cars that i've worked on that you still needed tach in order for the car to keep running. If i remember right the first one was a 99 ram. Would die out instantly. Then from there i hooked up tach, programmed it and was good to go. Had af ew others but can't quite remember what ones. Since then i still hook it up on all of them.
rubbish red 240sx
rubbish gold 240sx
rubbish
» Return to Nissan Audio / Entertainment / Security
