That's what I have. Autozone nor walmart don't have both sizes on the same wipers. I could get 2 different brands to get original sizes but I'm ok with 1" bigger.Pescakl1 wrote:If you cannot find a 14" blade for the passenger side, buy a 15", it will fit too.
is that the "farting" type sound the wiper makes when there is not enough water on the window.... because my rear wiper blade makes a rubbing noise right after its first wipe and continues...is this normal or can the dealer fix this???skholla wrote:my stock wipers chatter but i only have 5000km on my rogue. will try applying some rain-x and see if that helps, when they wear out i will replace them with some bosch icons. ive heard good things about them, they arent too expensive on amazon.com either...
http://www.amazon.com/Bosch-42...XK79U
http://www.amazon.com/Bosch-41...XK79U
I got those Michelin (from last year, so not sure if it is HydroEdge) and vs the walmart brand, Walmart got better result for the moment. I will see with snow later.skholla wrote:Has anyone tried the Michellin HydroEdge wipers from Costco?
