How To: Replacing Cigarette lighter, Heated Seat Lights and Rear Defrost w/LEDs
slickroger
Car: 2001 Nissan Pathfinder
First off if you don't know anything about resistance, LED's, soldering or risk taking do not attempt this. If your switches stop working i can only try to help with no guarantees.
Cigarette Lighter Ring
Here is my blue Led i cut the stems and bent them to sit in the original light housing.
I added a resistor in line with the Housing
Heated Seat Switches
The switch came apart real easy just a couple of very noticable clips. after opening the switch i cut a metal lead to make space for a resistor and LED
Finished and back together
Same concept for the rear defroster
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
awesome im so glad someone finally proved that you CAN change the heated seat switch light. How did you open up the casing? i broke mine and had to get a new switch and havent retried since.
great work roger
JHC828
Car: M56 S / Escalade ESV Platinum / Lexus LS F Sport
FX50 S & M45 - sold
Looks great!!!
So what's left to do? I still haven't seen the compass/outside temp screen done yet... Do you think that might be in your future?
I just want to send my truck with you for a few days and have everything changed to blue inside! lol
slickroger
i should be done everything by next week pictures will come just waiting on certain lights
slickroger
the heated seat lights look purple in person because of the orange tint on the see through part of the switch any ideas on what color would make that light look blue?
Turbogst
Car: 04 Pathfinder SE 4x4, 10 Acura TL AWD, 08 Zo6
anyway to use a corner of some sand paper to scratch it off? I know some guys were doing this to gauge needles to change the color
Towncivilian
Car: 2001.5 Nissan Pathfinder SE 3.5L 2WD A/T
2007 Nissan Altima 2.5L CVT
2012 Nissan Sentra 2.0L CVT Special
2012 Infiniti G37 Sedan 7A/T
What kind of resistors will work for the LEDs? I'm getting some LEDs to replace the switch pack LEDs, and went with the 15-ohm 1/2 watt 5% tolerance resistors that were suggested in the guide. Will those work fine for the hazard button and rear defroster button?
Pwnin O'Brien
Towncivilian wrote:What kind of resistors will work for the LEDs? I'm getting some LEDs to replace the switch pack LEDs, and went with the 15-ohm 1/2 watt 5% tolerance resistors that were suggested in the guide. Will those work fine for the hazard button and rear defroster button?
It depends on the drop voltage of your new LED's, it differs from color-to-color. Are you using 3mm or 5mm LEDs in the switches?
Towncivilian
I bought 10 of these LEDs for use in the door switch packs and the hazard button/rear defroster, with one left over as an extra in case I mess up an LED. I bought 2x5-pack of 15-ohm 1/2 watt 5% tolerance resistors from Radio Shack as well.
Pwnin O'Brien
Towncivilian wrote: I bought 10 of these LEDs for use in the door switch packs and the hazard button/rear defroster, with one left over as an extra in case I mess up an LED. I bought 2x5-pack of 15-ohm 1/2 watt 5% tolerance resistors from Radio Shack as well.
Those LEDs have a forward voltage of 3.4V and a forward current of 20mA. For a single LED in the switch you need at least a resistance of 530ohms. So you should get a pack of 560ohm resistors (0.5W) with a 5% tolerance. If you were to use the 15ohm resistors you currently have the LEDs would blow out almost instantly.
Towncivilian
Okay, I'll return those resistors I bought and buy the 560ohm instead. Thanks!
Towncivilian
Does anybody have any pictures of this mod specifically inside the rear defroster or hazard light buttons? I'm having trouble with soldering the resistor in a way that there'll be enough space to reassemble the housing and already wasted a resistor and LED. Plus the damned switches are difficult to reassemble. I almost gave up on trying to reassemble the hazard light switch until I noticed the turn signals don't function at all unless the switch is properly installed (not just having the base plugged in), so had to fiddle with it for several more minutes to assemble it before I could drive safely.
Towncivilian
Don't these have a forward current of 30mA, which would change their requirements to 353.3 ohms at 14v (even fewer ohms at 12v or less)?
jhong1226
Car: 1999 Infiniti QX4 2011 Nissan Altima 2.5s
did this 2 days ago but i used 12v led instead so did not have to bother with resistors. did not find led at radioshack thats 12v so i ordered them on ebay. $6 got me 5 12v 3mm white led's.
