GODCHSR
Slow Poke
Online
1996 Nissan 240sx
Kansas City Mo
10-28-2006
| « Re: Positive Crankcase Evacuation Explained (WDRacing) | 12:21 PM 8/26/2009 |
| Quote, originally posted by WDRacing » | The other thing you can do is run a header mounted evacuation system. They are under $100 but only pull blowby when you're under a load. When idling there won't be enough exhaust flow to create the venturi required to pull the blowby. I also can't say without speculation what rpm and load would be enough to start the venturi effect. I'd use this method combined with the vacuum pump if I wanted the best of both worlds. WD |
This is what I am familiar with. Your Constructive Criticism of it could also be applied to the factory system though. Without higher RPMs or WOT you don't have a ton of vaccum either... so I think the Exhaust pulling method is best because it creates vacuum and also still has to travel through the Catalytic Convertor for those who are environmentally conscience.
WDRacing
Porn Crusader
Online
1995 240SX, K5 Blazer
USA
11-25-2002
| « Re: Positive Crankcase Evacuation Explained (GODCHSR) | 12:45 PM 8/26/2009 |
I've read some really good things about header systems, however they are usually placed near or at the collector where the exhaust gas velocity is extremely high. In our case they'd be mounted after the O2 sensor which is already at least a foot away from the turbine outlet. So I don't know how much exhaust energy will available or at what rpm range. This method also won't work for those that need to pass the sniffer. Since it dumps a crap load hydrocarbons right onto the cat...lol. But there are ways around it etc...just something to bare in mind.I'm probably going with the GM Vacuum pump. I've read that if done correctly it actually put enough vacuum on the sump that it stopped a rear main seal leak. That's impressive for a $40 pump and some heater hose...lol. Combine the 2 and you'd be golden
CEO
03 G35C s/c, 93 S13 Vert KA-T, 09 Cube, 72 240Z RB25, 63 NL320, 67 WRL411, 67.5 SPL311, 68 510
Phx, AZ
4-29-2002
B, I want some specifics on that.I'm just running a breather, and you KNOW how much work I put into my motor... Plus the fact that I kept stock compression (actually probably HIGHER, since it's built to closer tolerances)... I could probably use this.
TEAM NICO: 146,000 Nissan enthusiasts strong.
 REGISTER NOW!!!!
NICOclub on Facebook
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (AZhitman) | 2:01 PM 8/26/2009 |
Not a problem brosef.Here's the Summit Racing Header Mounted Kit, $39 for the whole kit, minus 5/8's hose.
Let me dig up the part numbers for the Electric Pump stuff. WD
GODCHSR
Slow Poke
Online
1996 Nissan 240sx
Kansas City Mo
10-28-2006
| « Re: (WDRacing) | 2:05 PM 8/26/2009 |
GM part number 12554580
Pretty basic setup
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (GODCHSR) | 2:09 PM 8/26/2009 |
With that particular pump I believe you have to take it apart and remove a filter from the inside to maximize the suction of the pump. Also, a separator is a must for the GM pumps if you want long life. If oil gets inside they die fairly quickly by everyhting I've read.That is the pump I'll probably use though. I'm hunting for a few alternatives right now. Got a link that sells those pumps new? WD
kouki_hmongster
Want 97 kouki
Pomona ca
6-21-2008
| « Re: (WDRacing) | 2:31 PM 8/26/2009 |
well explained....now lets hope this clears up all those mix ups. i've been reading other peoples info and most of them are misleading, even on the Ka-t.org.here's the way i did mine to improve my stock PCV system. http://forums.nicoclub.com/zer...06595 i like the exhaust gas set-up since it would have vacuum during boost when the PCV closes. Vacuum pump would be really nice too.
I've been really busy but i will take pictures of my setup collecting blowby gas to prove that this really works.
supra33202
San Francisco CA
10-17-2007
| « Re: (WDRacing) | 4:42 PM 8/26/2009 |
Is there any how-to-install guide for header mounted evacuation system?http://www.summitracing.com/pa...large Thanks!
ace0073
1969 datsun 510
huntington beach ca
11-9-2006
| « Re: (supra33202) | 6:18 PM 8/26/2009 |
similar pump i think:http://cgi.ebay.com/ebaymotors....m245 also here is a site that I read on the subject. It has some good info, some not applicable to our setups but good none-the-less: http://www.dragstuff.com/techa....html
Modified by ace0073 at 6:30 PM 8/26/2009
GODCHSR
Slow Poke
Online
1996 Nissan 240sx
Kansas City Mo
10-28-2006
| « Re: (ace0073) | 6:46 PM 8/26/2009 |
That Ebay link actually looks like it was designed for this purpose. Sweet!
D-UNIT
from a 91' S13 (15.014 @ 94.56mph)
Kaneohe , HI hi
6-24-2003
So what do you do about tuning. You are releasing metered air out of the system. Blow by or not the pcv system is after the MAF so it is accounted for by the ecu.
 154hp and 158ft-lb of torque -- bone stock top and bottom end! <--- @ 176,890 miles - booya!
kouki_hmongster
Want 97 kouki
Pomona ca
6-21-2008
| « Re: (supra33202) | 1:38 AM 8/27/2009 |
You seem to have done a lot of research on this but the good thing is i think you finally understand the how the PCV system works. I remember giving you info about my set-up and i guess you ignored it so i didnt care to help...but i guess now you KNOW!
GODCHSR
Slow Poke
Online
1996 Nissan 240sx
Kansas City Mo
10-28-2006
| « Re: (D-UNIT) | 6:41 AM 8/27/2009 |
Modified by GODCHSR at 3:33 PM 8/27/2009
WDRacing
Porn Crusader
Online
USA
11-25-2002
| Quote, originally posted by D-UNIT » | | So what do you do about tuning. You are releasing metered air out of the system. Blow by or not the pcv system is after the MAF so it is accounted for by the ecu. |
Don't mistake what I'm saying. The system will work fine if you add a air / oil separator and a new check valve to the stock setup. The people that are adding an exhaust mounted evac system and wiring up vacuum pumps should be quite able to tune the car themselves. Or at least they are aware that when you change things on the motor you need to verify the timing and AFR's. If you're wondering how much of a change this will cause simply unhook the vac line coming from the PCV valve and plug it. Check you AFR's and base timing. Tune accordingly. WD
trackslut240
1993 Nissan 240SX
chicago IL
8-28-2004
| « Re: (WDRacing) | 6:52 PM 8/28/2009 |
WD thats an awesome explanation of the whole PCV mystery. thanks any links to getting the check valve coz i looked one up on mcmaster carr, which seems to do the job well. http://www.mcmaster.com/#about...e3ue8 the valve i thought of is 7775K61 for $11.97 1/8" cracking pressure .3 psi, also the lowest Cv(Cv factor (coefficient of volume) is the amount of water (in gpm) that will pass through a fully open valve at 1 psi with 1 specific gravity (60° F).) just need you inputs, thanksnow with the vacuum pump, would it be long lasting on a daily driver? i was thinking of making it run with the check vavle, so it would kick on at idle and WOT(tied in to the TPS). the rest of the time just use the check valve method. maybe i am wringing my brain too much? this pcv is no joke, the tuner shop i went to for some welding told me to vent it atmosphere...
koukiKA240
Track Feind
1991 240sx KA-T
Houston Texas
5-25-2004
what about a system that sources a vacuum before the turbo after the MAF, to a oil seperator, to the engine?If running the vacuum pump would a catch tank with baffles and packing be enough to protect the pump?
Modified by koukiKA240 at 3:24 AM 8/29/2009
GODCHSR
Slow Poke
Online
1996 Nissan 240sx
Kansas City Mo
10-28-2006
| « Re: (trackslut240) | 8:56 PM 8/28/2009 |
| Quote, originally posted by trackslut240 » | this pcv is no joke, the tuner shop i went to for some welding told me to vent it atmosphere...
To be fair though, that will prevent the RMS from blowing out... because the 'mini' filter becomes the path of least resistance. It just won't increase oil life.
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (koukiKA240) | 6:30 AM 8/29/2009 |
| Quote, originally posted by koukiKA240 » | | what about a system that sources a vacuum before the turbo after the MAF, to a oil seperator, to the engine? If running the vacuum pump would a catch tank with baffles and packing be enough to protect the pump? Modified by koukiKA240 at 3:24 AM 8/29/2009
Did you read the part that said THERE IS NO VACUUM BEFORE THE TURBO? You can't source something that isn't there. Vacuum is created by a force pulling air against a restriction. You have air being pulled through the turbo but there is no restriction on the other end to cause the vacuum. Does that help? | Quote, originally posted by trackslut240 » | WD thats an awesome explanation of the whole PCV mystery. thanks any links to getting the check valve coz i looked one up on mcmaster carr, which seems to do the job well. http://www.mcmaster.com/#about...e3ue8 the valve i thought of is 7775K61 for $11.97 1/8" cracking pressure .3 psi, also the lowest Cv(Cv factor (coefficient of volume) is the amount of water (in gpm) that will pass through a fully open valve at 1 psi with 1 specific gravity (60° F).) just need you inputs, thanksnow with the vacuum pump, would it be long lasting on a daily driver? i was thinking of making it run with the check vavle, so it would kick on at idle and WOT(tied in to the TPS). the rest of the time just use the check valve method. maybe i am wringing my brain too much? this pcv is no joke, the tuner shop i went to for some welding told me to vent it atmosphere...
I don't know if I'd use the valve in your link. I know for a fact that the PCV from the 87 Buick GNX will work very well and it's only $3 and available at any Autozone Buick GNX PCV Valve
You can either ADD that one inline or replace the stock one with it. I'd add it in WD
trackslut240
1993 Nissan 240SX
chicago IL
8-28-2004
| « Re: (WDRacing) | 9:31 AM 8/29/2009 |
thanks WD, that should make my oil life more than 1500 miles, now to get back to work and get that motor running. +1 for Sticky!!
Daily Driven 240
s-13
montreal qc
3-27-2007
| « Re: (trackslut240) | 11:38 AM 8/29/2009 |
thanks WD for the buick pcv valve alternative, i was looking for one way check valves for air compressors but it seems that around were i live it isnt easy to find. The 87 buick gnx pcv valve it is then.
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (Daily Driven 240) | 2:00 PM 8/29/2009 |
You guys have Autozone up in Canada?
Chris28
92 s13 KA-T
757 VA
7-14-2007
| « Re: (WDRacing) | 2:43 PM 8/29/2009 |
Hmmmm maybe this is why I can't get my oil pan to seal. It's warped, but I figured enough RTV would seal it.When my engine is out in a few weeks I'm planning on installing a check valve and a home depot filter.
 http://ignitesoul.blogspot.com/
shimizu_17
Yuba City ca
2-23-2004
| « Re: (Chris28) | 10:38 AM 8/30/2009 |
Good thread thanks WD
Daily Driven 240
s-13
montreal qc
3-27-2007
| « Re: (WDRacing) | 11:49 AM 8/30/2009 |
we have alot of auto parts stores just their not called autozone, but im sure i wont have a hard time finding the buick gnx pcv valve, it was the one way check valves for air compressors i was having a hard time finding. so thanks for the alternative makes my life easier.
Chris28
92 s13 KA-T
757 VA
7-14-2007
| « Re: (Daily Driven 240) | 1:23 PM 8/30/2009 |
Wait, so that Buick PCV valve is a check valve?
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (Daily Driven 240) | 2:19 PM 8/30/2009 |
| Quote, originally posted by Daily Driven 240 » | | we have alot of auto parts stores just their not called autozone, but im sure i wont have a hard time finding the buick gnx pcv valve, it was the one way check valves for air compressors i was having a hard time finding. so thanks for the alternative makes my life easier. |
I was just messing with you, I like to give all our Northern members a hard time The staff guys we have up your way catch hell in the Mod forum | Quote, originally posted by Chris28 » | | Wait, so that Buick PCV valve is a check valve? |
A PCV valve IS a check valve. All it does is allow liquid or gas to move in one direction. Any reverse flow closes the valve. WD
Daily Driven 240
s-13
montreal qc
3-27-2007
| « Re: (WDRacing) | 8:21 PM 8/31/2009 |
thanks for the warm welcome WD lol.
supra33202
San Francisco CA
10-17-2007
| « Re: (kouki_hmongster) | 11:48 PM 8/31/2009 |
| Quote, originally posted by kouki_hmongster » | | well explained....now lets hope this clears up all those mix ups. i've been reading other peoples info and most of them are misleading, even on the Ka-t.org. here's the way i did mine to improve my stock PCV system. http://forums.nicoclub.com/zer...06595 i like the exhaust gas set-up since it would have vacuum during boost when the PCV closes. Vacuum pump would be really nice too.
I've been really busy but i will take pictures of my setup collecting blowby gas to prove that this really works. |
Looking forward for your pictures.
redhb240SXS13
1992 240sx Coupe and 1995 240sx
Greenwood IN
11-17-2006
| « Re: (supra33202) | 6:24 PM 9/1/2009 |
So WD, what your suggesting is to run the stock PCV valve to a check valve, out of the check valve to a catch can/ oil separator, and back into the four ports on the bottom of the upper intake mani? I heard people plug those holes because they are a common boost leak nuiscense. If thats the case where would you suggest returning the air back into the system at?I may be completely off on this, still getting a grip on this PCV business.
WTB S13 Hatch Shell in or around IN. E-mail is in profile.
supra33202
San Francisco CA
10-17-2007
| « Re: (redhb240SXS13) | 12:10 AM 9/2/2009 |
| Quote, originally posted by redhb240SXS13 » | | So WD, what your suggesting is to run the stock PCV valve to a check valve, out of the check valve to a catch can/ oil separator, and back into the four ports on the bottom of the upper intake mani? I heard people plug those holes because they are a common boost leak nuiscense. If thats the case where would you suggest returning the air back into the system at? I may be completely off on this, still getting a grip on this PCV business. |
Actually, I have the same question. So WD, what's your opinion on removing the PCV system and plug those holes in regards to the risk of boost leak? http://www.ka-t.org/forums/vie...f5ca7
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (supra33202) | 7:44 AM 9/2/2009 |
Every vacuum line is a potential boost leak. Just replace the lines and use tie straps or even a drop of super glue.Or just lose the PCV system entirely like I described above. Worrying about a "possible" boost leak isn't worth not having crankcase evacuation. Don't believe anyone that says different, they simply don't understand. WD
supra33202
San Francisco CA
10-17-2007
| « Re: (WDRacing) | 2:52 PM 9/2/2009 |
Hopefully, kouki_hmongster or other people can show us some pictures for their improved PCV system setup. It would clear alot of things.WD, thanks for your input.
Ruff Ryder 6
1990 240sx coupe, 1990 N/A 300zx
Maryville TN
4-15-2006
| « Re: (WDRacing) | 11:46 AM 9/19/2009 |
So have you completed your setup yet? I am wanting to go hunt for a pump in the 'yard but wondered which one you went with.
Buy my engine and exhaust parts: http://forums.nicoclub.com/zerothread/335980
neverlift
Mad Thrasher
PIGNOSE #19 turbo piggy
sunshinestate
4-24-2006
| « Re: (Ruff Ryder 6) | 1:51 PM 9/19/2009 |
this should be sticky as hell wdI have pics somewhere of the last time I cleaned mine, it was a tar like substance that smelled like burnt fuel and oil nasty as f***. I know it works better cause I had the line kinked due to a hasty engine install, my oil lasted only 1500ish miles before I felt the NEED to change it.... 500 mile mark normally the oil has turned and it now stays that golden color longer.
Glad a thread with research and info has landed, dont let it fall off the front page maybe people will find it
PIGNOSE SQUAD MEMBER # 19
 someone buy my wheels http://forums.nicoclub.com/zer...57581---------------------------------- r.i.p. Dad I miss you 06/14/54~04/18/09 ---------------------------------- r.i.p. Lee 09/01/89~09/28/06
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (neverlift) | 2:39 PM 9/19/2009 |
It's already in the sticky homegirl I did contemplate sticking this thread all by itself. I think this topic slips 90% of most DIY guys minds during a project WD
neverlift
Mad Thrasher
sunshinestate
4-24-2006
| « Re: (WDRacing) | 8:58 PM 9/19/2009 |
girlfriend you dont even know how long I went with my vc just ota as well as the pcv :barf
supra33202
San Francisco CA
10-17-2007
Any pictures after the installation?
neverlift
Mad Thrasher
sunshinestate
4-24-2006
| « Re: (supra33202) | 6:12 AM 9/22/2009 |
its real simple actually, I just got some hose and an oil/air seporator from one of may favorite tuning shops(harbor freight ) then run one end of hose to the stock pcv and the other to the 4:1 tee coming off the manifold cut it where you want to place your separator, if you get the one like me use a small bolt and hose to keep it from being a vac leak. It does have some flaws to it, but it gets the job done. it has ups and downs. The thing has no filter which was a plus when I cleaned it ,a little dawn in both sides ,rub a little and its sparkly clean again. But the design is to let the oil drip out of the bottom, fine and dandy on a air line for tools and what not but not so hot as its a vac leak, thats when you put the plug on.The leak is minute but there as you can hear a clear hiss unless its blocked..
I'll go snap a shot, I didnt clean it with my last oil change so it should be dirty still.
WDRacing
Porn Crusader
Online
USA
11-25-2002
| « Re: (neverlift) | 7:38 AM 9/22/2009 |
Dirty is good because it'll show how much oil/carbon would have ended up INSIDE the intake manifold otherwise. Put steel wool inside the seperator to assist in removing the oil from the air. I'd come up with a valve or something for the hole in the bottom. Any leak is a bad thing IMO.
| First 1 2 3 > Last |
