adjustable exhaust cam sprocket
Discuss topics related to the QR series engine.
08specv
Car: 08 Sapphire Blue Spec V
does anyone know if using this to remove overlap would work on the new qr25?
-matt
RED_DET
Vendor
Car: 2004 Infiniti G35 Sedan 6 spd
2011 Infiniti G37x
1992 Nissan Sentra SE-R SR20DET
Chevrolet Corvette Z06
on the stock cams?
08specv
yeah dont the 02-06 qr's use exhaust valve overlap instead of an egr system to help clean up the exaust a bit, i heard people using cam gears to take this away and gain a few ponies. I was wondering if this system is used in the new qr's.
-matt
nametakennow
Car: '06 MINI Cooper S
Yes, Nissan skipped EGR and used a bit of overlap to provide the same emissions benefit. This sounds like a fairly reasonable way to gain a few hp, but probably not really worth the cost without upgraded cams.
08specv
ok, i wanna do cams but i'll have to wait until we get some support.
-matt
nametakennow
One foreseeable concern is that this may alter the exhaust air composition and, via the reading at the O2 sensor, cause the ECU to throw a code and/or alter other parameters to get the mixture it's looking for.
Q45tech
EGR [whether cams or piping ] is only active at steady speed cruise [2,000-3,300 rpm] and light load. It is shut off at idle and during acceleration.
Careful you don't try to solve a nonexistent problem and create a bigger one.
djtorello
Car: 2008 nissan Sentra SE-r
T
08specv wrote:ok, i wanna do cams but i'll have to wait until we get some support.
-matt
here are quite a few companies that you can get custom cams from. I have a custom set, im quite happy with. BTW, if you can make friends with a tech at a dealership, see if someone can bump your timing 2 degrees with the Consult tool. those 2 degree's is a nice bump in performance, though your mileage will decrease a bit.
Return to “QR Series”
