c72c »
https://forums.nicoclub.com/c72c-u137719.html
Sat Aug 08, 2009 8:09 am
I got a 96 s14, sr20de 5spd. ONLY after start up i get a rattle-ish grinding from the mission. it will only do it in 1 or R. I'll put it in gear and about 1/4 off the clutch it'll start, it'll grind anywhere between 1-10mph then goes away, unless i stay constant under 10. when i first start it's somewhat obnoxious but as i increase speed it smooths then stops. It does this warm and cold, but after couple hours cruisin, stop, and startup again, it seems a bit worse. There was also one time i put it on stands, put it in first and let it go, it did the same grinding but the whole time in 1st till i shifted. then i stopped, put it back in first still runnin, no grind??? i'm stumped, as is everyone else i've asked.I bought it in march and it was grindin when i bought it, had it drained and filled about 2 months later, got a new clutch and release bearing last week. I'd like to have a possible suspect before droppin it to fix(can't afford down time).-ALSO, there's times i'll push half throttle in low gears and when it would normally break loose, it feels like somethins slippin a bit. feels just like when a clutch is goin, but it did it today and like i said, new clutch. I didn't notice this till last month.
