loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Nov 05, 2009 9:13 pm
The Brake light comes on if the brake reservoir level is low or the alternator is failing, but is usually accompanied by other lights.
Don't buy an alternator unless you have confirmed it's bad. Best place to buy OEM parts is from IoS, inifnitipartsUSA.com @ 25% off MSRP. Of course there will be a delay due to shipping. If you have to buy non-OEM alternator, avoid Kragen.
You jump-started the car and yet it still won't start (just crank) is an indication that you have problems aside from the battery-alternator. The car should have started but will die once the jumper cable is disconnected, if the alternator is bad.
In your original post, you have code 1320 and your mechanic replaced all the coils and plugs. It's possible that the Crank Position Sensor is malfunctioning. Your mechanics should have checked them before replacing all the coils and plugs. Also, perform a 'spark test' to see if the ignition system is working. Procedures are available from the FSM. You need to buy or borrow an OBD II scanner to find out if you have fault codes.
Another possibility is a bad harness or connection to the ECM or even poor ground connection. Did you clean the ground connections as I recommended in the earlier posting? If you haven't done so, remove them and clean the terminal lugs and the grounding point. The ground wires are located on top of the engine, besides the intake plenum, close to cylinder #2. After installation, apply dielectric grease to avoid oxidation (corrosion). Also, before attempting another start, try to wiggle the main harness. You may have a loose connection there. As for checking the connections to the ECM, although it's in the FSM (linked given to you by "audtatious"), it would be better to have it done by your mechanic. Also, ensure the MAF sensor connector is clean. Use a zero-residue contact cleaner to clean it and then apply dielectric grease to avoid corrosion.
You may also have problem with the fuel delivery - faulty pump, fuse and/or clogged fuel filter. The fuel pump is located in the tank and is accessible from the rear seat, pax side. Turn the ignition to ON (do not start) and listen for the pump - it should hum (not whine) for @ 5 secs then shut down. If Ok, then you have to check the fuel pressure. The best way to verify this is by connecting a fuel pressure gauge. Ensure the fuel line is empty before doing so - FIRE HAZARD. With ignition ON (engine not running) pressure should be @ 43 psi. If the engine is running, the pressure is @ 34 psi.
