 HELP!!! Can't remove sway bar link on my old trusty (and rusty) 1996 Pathfinder
VancouverPF
1996 Pathfinder
Vancouver BC
7-3-2009
hi nico friends,
I'm really desperate now. Basically I've ordered the sway bar links & set about removing the old (which had one end popped out of the ball joint).
Removing the one which has popped out was easy : I used a lock wrench on the exposed ball portion & unscrewed the nut on other end.
But the one which is still "okay" (meaning the ball did not pop out), is the tricky one. I suppose the easiest way is to somehow separate the old sway bar link knuckle from the joint, and use the same trick with lock wrench. Trouble is I can separate them!
Can someone recommend a way to do that? I tried using a hammer but it would not budge. Any help is deeply appreciated. Thanks in advance.
here are the pics i just took :
http://www.flickr.com/photos/7...42486/
http://www.flickr.com/photos/7...37683/
The thing is the original does not have nut for me to grip with a 2nd spanner. The new ones has nut on the part that rotates. Tks!
Zac
Modified by VancouverPF at 12:44 AM 7/4/2009
Modified by VancouverPF at 12:48 AM 7/4/2009
Modified by VancouverPF at 2:25 AM 7/4/2009
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
 « Re: HELP!!! Can't remove sway bar link on my old trusty (and ... (VancouverPF)
I dont know exactly the look of the joint your trying to seperate, but the angled forks and a 2-5lb hammer have never ever let me down, but they do some damage if your not careful, but it wont matter if your replacing the parts.
Built... Not Bought
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
 « Re: HELP!!! Can't remove sway bar link on my old trusty (W O T)
Sorry for the huge pic but it was the best one on page one of google images, its called a pickle fork aparently, they cost like $15 or you can rent them for a couple bucks Im sure at crappy tire
Like I said I dunno what youre trying to seperate exactly
VancouverPF
1996 Pathfinder
Vancouver BC
7-3-2009
hi WOT ... thanks for trying to help. here are the pics i just took :
ps. Sorry i can't figure out how to embed pictures in forum yet.
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
 « Re: HELP!!! Can't remove sway bar link on my old trusty (VancouverPF)
Oh,,, i was way off eh, I actually had the exact same problem youre having, if theres no way to get a grip on it (like mine was) all I did was attach a 3" metal cutting blade to my jigjaw and CUT IT OFF
I just did this a month ago, its pretty soft metal, the threads cut easy as pie
VancouverPF
1996 Pathfinder
Vancouver BC
7-3-2009
ok, thanks for the tip ... that suggestion worked !
fukinitupagain
1997 Nissan Pathfinder SE & POS 1994 Nissan Sentra (awaiting a SR20DET swap)
Psychoville and I am the mayor
4-2-2007
Quote, originally posted by VancouverPF »
Good thing cause I would've been no help. I snapped mine on the trail & then took it off later cause it was rattling...
97 Nissan Pathfinder SE with 2" AC lift coils, KYB-GR2 strurs, Rancho 9000 shocks, broken front & rear anti-sway bar (removed), Magnaflow exhaust, custom tube rear bumper, cut-up front bumper (falling off), Nissan Quest alternator, Warm manual hubs, custom sliders, skull sift knob, Herculined lower doors & interior, pine tree air freshener, custom roof rack, custom sliders, a bunch of lights, 32x11.5 BFG Mudterrains on 15x8 black Rock Crawlers, 8500lb Mile Marker winch, Cobra CB & external speaker, 1 Pitbull & a partridge in a pear tree...
http://www.cardomain.com/ride/3134446
