 PVC Valve for the 3.3L in 2000 QX4
Mikey178
2000 Infiniti QX4
Brampton On
6-14-2009
Just wondering if anyone knows where the PVC valve is located in the 2000 QX4. I can't seem to find this. I bought a new one to replace but can't seem to find the location.
Anyone got any ideas??
2000 Infiniti QX4
HID Headlights, Mesh grill, 20" Chrome Rims, Painted calipers and drums, Drilled Rotors, Custom Magnaflow dual in dual out exhaust system, 2 - 10" JL Audio, 2 - JBL Amps, 2 - 6x9 JBL 3-way speakers, JL Audio speakers are in all doors each with component tweeters, 7" in dash dvd/mp3/divx/sd/ipod/usb player, LED interior lights, LED underlights, Bosch iridium 4 spark plugs, 2 way lcd alarm with remote starter
and much more.....
Check my QX4 out http://www.cardomain.com/ride/3310765
Ron Burgundy
1999.5 Nissan Pathfinder 3.3 LE
La Habra California
6-12-2009
 « Re: PVC Valve for the 3.3L in 2000 QX4 (Mikey178)
Well if its anything like the 2000 3.3L Pathfinder (which I can't guarentee it is, but its worth checking), there are two hoses coming out the engine block on the right side (driver's side) Pull the hose out thats closer to the windsheild (if it helps the area is called the upper intake manifold) Its threaded in that hole where the hose attaches.
I'm doing this tomorrow, i'll take and post pics. Hopefully it'll help.
Mikey178
2000 Infiniti QX4
Brampton On
6-14-2009
 « Re: PVC Valve for the 3.3L in 2000 QX4 (Ron Burgundy)
Thanks, i'll take a look to see if I find it as you've described but some pics would be good.
Ron Burgundy
La Habra California
6-12-2009
As requested...
Here is the engine compartment in full. We will be working in the area between the brake fluid resevoir (big round yellow cap) and the engine block (big silver thing in the middle)
Here is a close up on that area. Notice the four hoses in the center with the silver clips? The PCV valve is located inside the on the bottom right
Here is a picture with the hose removed. You can see the PCV slightly.
Close up picture of the PCV. It is quite a tight squeeze to get a ratchet in here so I removed the two hoses above it to make a little more room.
And last but not least - here is the PCV removed and the hole in which it threads into. Shake the valve and listen for a rattle. If it doesn't rattle - replace it!
Hope this helps!
Mikey178
2000 Infiniti QX4
Brampton On
6-14-2009
Thanks for that, I was able to change mine after your first description. I did take pictures myself of the location.
Hope this helps someone else as well, Thanks again to Ron for the pictures.
