New2Import
06 M45
Spring Hill Tn
1-29-2009
| « Re: Has anyone changed their own brakes (Indy Golfer) | 6:30 AM 7/3/2009 |
$900 WOW. I did C/D rotors and ceramic pads for half that myself. Very easy. Just need a C clamp to move pistons in calipers back with the the old pad in it. Some things you just have to do it yourself. Oil and brakes are just one of the few.
06 M45 stock for now 96 Impala SS 383 CI fully custom and runs high 11s 04 Dodge Ram SRT conversion (Daily Driver) 03 Stratus R/T (Daily Driver) Pics of Rides http://www.cardomain.com/id/xstinctSS
BigP
2006 M45
Atlanta Ga
3-28-2009
| « Re: Has anyone changed their own brakes (New2Import) | 6:38 AM 7/3/2009 |
Is there a tutorial somewhere on the web or does anyone teach this stuff to regular guys who are fairly mechanically inclined but just need to know the fine points and make sure they have the right tools? I know I could change pads if I had a step by step guide. I certainly would want it done correctly but I think dealers hold us hostage on this with knowledge they think we can't obtain.
New2Import
06 M45
Spring Hill Tn
1-29-2009
| « Re: Has anyone changed their own brakes (BigP) | 8:31 AM 7/3/2009 |
Great point. I first learned on just getting out there and just doing it. Not being afraid when I owned my first car at 17. I then got Haynes manuals on my cars since I always owned domestic.
Indy Golfer
2006 M45 Sport
Fishers IN
11-23-2008
| « Re: Has anyone changed their own brakes (New2Import) | 8:40 AM 7/3/2009 |
Thanks for the reply, looks like I need to start shopping.What brand of rotors and pads did you use? Did you notice any performance difference over the stock setup to warrant the extra cost? I think it would be nice if this forum had a "Do It Yourself" section like other forums have. Thanks again
New2Import
06 M45
Spring Hill Tn
1-29-2009
| « Re: Has anyone changed their own brakes (Indy Golfer) | 10:25 AM 7/3/2009 |
No big improvement with C/D rotors. If you go ceramic pads it keeps the dust off your rims. Im saving up for the BBK kit.
Manok
04 M45
va
9-21-2007
Can you take out two bolts? If so, you can change your brakes.
loystock
Maxima Moderator
97&03 Q45s, 97&99 I30s and 06 M35 Sports (04 G35-RIP)
San Jose CA
9-22-2003
| « Re: (Manok) | 2:01 AM 7/4/2009 |
Personally, I replace brake pads when thickness falls below 5mm, although minimum acceptable thickness is 2mm. Rotors need not be replaced unless they are cracked, severely warped, thickness is below spec. or upgrade is desired. A warped rotor may be turned for @ $20 each provided the resulting thickness does not fall below spec. Be careful when buying aftermarket brake pads. Some of them are too hard (and nois?) that your stopping distance may be affected. IoS at http://www.infinitipartsusa.com, has an additional 5% off extended until mid-July. IoS is one of NICO sponsors (I don't work for them) Below is a procedure for those who want to service their brake. I modified the procedure from FSM for clarification and inclusion of optional steps. M35/M45 Brake Pads Replacement Specification (from FSM) and Pricing from IoS: -Front Rotor: 28mm new/26mm minimum; Maximum Runout=0.035mm ($82.11 from IoS) -Rear Rotor: 16mm new/14mm minimum; Maximum Runout=0.055mm ($69.20 from IoS) -Front Brake Pads: 11mm new/2mm minimum ($61.33 from IoS) -Rear Brake Pads: 8.5mm new/2mm minimum ($58.66 from IoS) Tools and Materials Required -Tire wrench, jack and jack stand -Breaker bar (1/2” drive) -Ratchet Drive (1/2” or 3/8”) -Metric sockets (14mm for pin bolts, 21mm for lug nuts; 22mm for torque member bolts if rotor needs removal/replacement) -Torque wrench (32 ft-lbs for pin bolt, 72-87 ft-lbs for lug nuts) -C-clamp (for pushing the piston) -wire sufficient to support the brake cylinder body -optional steel brush to clean lug nuts and hub bolts -optional disc brake cleaner -DOT 3l Brake Fluid (32 oz), container and vinyl tube for optional Bleeding Brake System -PBC grease or CRC Disc Brake Quiet -suitable wipes/rugs Removal and Installation of Brake Pad (from FSM) REMOVAL 1. Remove tires from vehicle with power tool (or tire wrench or breaker bar with 21mm socket). 2. Remove lower sliding pin bolt (14mm socket). 3. Hang cylinder body with a wire, and remove pads, pad retainers, shims, and shim cover from torque member (Option: clean retainer and shims with brake pad cleaner). Note: If rotor needs to be removed – First remove both pin bolts and hang cylinder body. Then remove both Torque Member mounting bolts (breaker bar may be required with 22mm socket ) and pull out the torque member. Pull out the rotor (have them turned or replaced) CAUTION: Deform pad retainer when removing pad retainer from torque member. INSTALLATION 1. Apply PBC (Poly Butyl Cuprysil) grease or equivalent (or CRC Disc Brake Quiet) to between shim cover and shim. Install inner shim, inner shim cover to inner pad, and outer shim, outer shim cover to outer pad. 2. Install pad retainers and pads to torque member. 3. Press in piston until pads can be installed (use C-clamp and old brake pad to push piston), and then install cylinder body to torque member. CAUTION: In the case of replacing a pad with new one, check a brake fluid level in the reservoir tank because brake fluid returns to master cylinder reservoir tank when pressing piston in. NOTE: Use a disc brake piston tool (commercial service tool, or C-clamp) to easily press piston (use the old pad together with the C-clamp to press the piston until it is flush with the piston cylinder). 4. Install upper sliding pin bolt and tighten to the specified torque. Refer to BR-29, "Components". 5. Check rear disc brake for drag. OPTION: Bleed Brake System in sequence- rear right, front left, rear left and front right. Ensure brake reservoir level does not go below minimum or air will enter the system (spongy brake) 6. Install tires to vehicle (Torque lug nuts to 72-87 ft-lbs. Over-torquing may warp the rotor). Good luck Rod
BigP
2006 M45
Atlanta Ga
3-28-2009
| « Re: (loystock) | 7:55 AM 7/4/2009 |
This is great information...thanks. Mike
M45Caliber
2003 M45, 34K original miles, Pearl White, Chromes, Borla and 2008 EX35 Journey, Pearl White & Stone
Tempe AZ
6-3-2008
| « Re: (BigP) | 1:07 PM 7/4/2009 |
I now have almost 2000 miles on my new rotors and brakes, and in a word: AWESOME! I had Frozen Rotors and Hawk HPS pads installed on all four corners for the cost of new front rotors and pads via the dealer. I use the dealer for ALL other maintenance, except tires and brakes.These binders are MUCH more linear, have stronger stopping power at all speeds and have firmed up the brake pedal a little bit too. And virtually zero dust to boot. I had to brake very hard recently (from ~100 down to 65 - don't ask, don't tell, OK) and it was like a Star Fleet tractor beam grabbed the a**-end of my M and locked on. Absolutlely no shuddering and no fade. These brakes actually get a little stronger after they are warmed up a bit. Gave the seatbelt/shoulder harness a good test too. Search this forum for a few other posts on this topic, but the rotors AND pads for all 4 corners were around $600. My mechanic installed all of this for a flat $180. Once again -- these are not OEM -- these were the FROZEN ROTORS and HAWK pads. Unreal. I can recommend this set up without hesitation - best brakes I've used to date. Wish I had a set up like this back in my IMSA and SCCA days. I'd have been out-braking those pesky 930's into turn nine at Riverside and the corkscrew at Laguna.
BigHeadDennis
2006 M45 Sport, Ad Tech
Boston MA
3-17-2009
| « Re: (loystock) | 9:18 AM 7/7/2009 |
This is great, loystock - thanks! Do you have a similar write-up for replacing the rotors?--Dennis
| Quote, originally posted by loystock » | | Personally, I replace brake pads when thickness falls below 5mm, although minimum acceptable thickness is 2mm. Rotors need not be replaced unless they are cracked, severely warped, thickness is below spec. or upgrade is desired. A warped rotor may be turned for @ $20 each provided the resulting thickness does not fall below spec. Be careful when buying aftermarket brake pads. Some of them are too hard (and nois?) that your stopping distance may be affected. IoS at http://www.infinitipartsusa.com, has an additional 5% off extended until mid-July. IoS is one of NICO sponsors (I don't work for them) Below is a procedure for those who want to service their brake. I modified the procedure from FSM for clarification and inclusion of optional steps. M35/M45 Brake Pads Replacement Specification (from FSM) and Pricing from IoS: -Front Rotor: 28mm new/26mm minimum; Maximum Runout=0.035mm ($82.11 from IoS) -Rear Rotor: 16mm new/14mm minimum; Maximum Runout=0.055mm ($69.20 from IoS) -Front Brake Pads: 11mm new/2mm minimum ($61.33 from IoS) -Rear Brake Pads: 8.5mm new/2mm minimum ($58.66 from IoS) Tools and Materials Required -Tire wrench, jack and jack stand -Breaker bar (1/2” drive) -Ratchet Drive (1/2” or 3/8”) -Metric sockets (14mm for pin bolts, 21mm for lug nuts; 22mm for torque member bolts if rotor needs removal/replacement) -Torque wrench (32 ft-lbs for pin bolt, 72-87 ft-lbs for lug nuts) -C-clamp (for pushing the piston) -wire sufficient to support the brake cylinder body -optional steel brush to clean lug nuts and hub bolts -optional disc brake cleaner -DOT 3l Brake Fluid (32 oz), container and vinyl tube for optional Bleeding Brake System -PBC grease or CRC Disc Brake Quiet -suitable wipes/rugs Removal and Installation of Brake Pad (from FSM) REMOVAL 1. Remove tires from vehicle with power tool (or tire wrench or breaker bar with 21mm socket). 2. Remove lower sliding pin bolt (14mm socket). 3. Hang cylinder body with a wire, and remove pads, pad retainers, shims, and shim cover from torque member (Option: clean retainer and shims with brake pad cleaner). Note: If rotor needs to be removed – First remove both pin bolts and hang cylinder body. Then remove both Torque Member mounting bolts (breaker bar may be required with 22mm socket ) and pull out the torque member. Pull out the rotor (have them turned or replaced) CAUTION: Deform pad retainer when removing pad retainer from torque member. INSTALLATION 1. Apply PBC (Poly Butyl Cuprysil) grease or equivalent (or CRC Disc Brake Quiet) to between shim cover and shim. Install inner shim, inner shim cover to inner pad, and outer shim, outer shim cover to outer pad. 2. Install pad retainers and pads to torque member. 3. Press in piston until pads can be installed (use C-clamp and old brake pad to push piston), and then install cylinder body to torque member. CAUTION: In the case of replacing a pad with new one, check a brake fluid level in the reservoir tank because brake fluid returns to master cylinder reservoir tank when pressing piston in. NOTE: Use a disc brake piston tool (commercial service tool, or C-clamp) to easily press piston (use the old pad together with the C-clamp to press the piston until it is flush with the piston cylinder). 4. Install upper sliding pin bolt and tighten to the specified torque. Refer to BR-29, "Components" . 5. Check rear disc brake for drag. OPTION: Bleed Brake System in sequence- rear right, front left, rear left and front right. Ensure brake reservoir level does not go below minimum or air will enter the system (spongy brake) 6. Install tires to vehicle (Torque lug nuts to 72-87 ft-lbs. Over-torquing may warp the rotor). Good luck Rod
szhosain
Super Moderator
2003 M45. Brilliant Silver.
San Jose CA
7-23-2002
| « Re: Has anyone changed their own brakes (New2Import) | 12:16 PM 7/7/2009 |
| Quote, originally posted by New2Import » | $900 WOW. I did C/D rotors and ceramic pads for half that myself. Very easy. Just need a C clamp to move pistons in calipers back with the the old pad in it. Some things you just have to do it yourself. Oil and brakes are just one of the few. |
Please do also remember to clean and regrease the caliper pins ... to avoid sticking pins! Z
szhosain
Super Moderator
San Jose CA
7-23-2002
| « Re: (BigHeadDennis) | 12:22 PM 7/7/2009 |
| Quote, originally posted by BigHeadDennis » | | Do you have a similar write-up for replacing the rotors? |
The info is in the FSM (link is in my sig - my first post in this thread above). Although, I am sure that real world experience would modify it - similar to what Rod did for the pad change description he posted above. Z
jedgington
2006 M35x / Journey/Tech / Graphite Diamond
Cedar Falls IA
8-1-2007
| « Re: (loystock) | 3:06 PM 7/19/2009 |
Thanks for the info, loystock.I went to IoS website to order OEM replacement front brake pads for my 06 M35X. If you browse their catalog, and click Brakes - Brake components - Front pads, you are presented with one option, the pads you listed for $61.33. However, if you go a different route and click Front Suspension - Brake components - Front pads, you are presented with two options, the pads for 2WD ($61.33) and for AWD ($76.66). Different prices, so I assume different parts. When looking for aftermarket brake pads at other websites, I've noticed that their front pads are listed as replacements for the base 2WD model, sport model, and the X AWD model. So, my question is: are OEM replacement brake pads different for 2WD and AWD? If so, what makes the AWD model cost almost 25% more?
Jason Edgington 06 M35x / Journey/Tech / Graphite Diamond
loystock
Maxima Moderator
San Jose CA
9-22-2003
| « Re: (jedgington) | 12:58 AM 7/20/2009 |
I checked the FSM which applies to both 2006 M35 and M45. The SDS (Service and Data Specifications) provides only one pad dimension for the front pads. So I'm not sure what is the difference. Maybe other forum members can chime in.
ArbitrageMan
2006 M45 Sport
Washington DC
10-14-2008
| « Re: (M45Caliber) | 6:14 PM 7/20/2009 |
| Quote, originally posted by M45Caliber » | | I now have almost 2000 miles on my new rotors and brakes, and in a word: AWESOME! I had Frozen Rotors and Hawk HPS pads installed on all four corners for the cost of new front rotors and pads via the dealer. I use the dealer for ALL other maintenance, except tires and brakes. These binders are MUCH more linear, have stronger stopping power at all speeds and have firmed up the brake pedal a little bit too. And virtually zero dust to boot. I had to brake very hard recently (from ~100 down to 65 - don't ask, don't tell, OK) and it was like a Star Fleet tractor beam grabbed the a**-end of my M and locked on. Absolutlely no shuddering and no fade. These brakes actually get a little stronger after they are warmed up a bit. Gave the seatbelt/shoulder harness a good test too. Search this forum for a few other posts on this topic, but the rotors AND pads for all 4 corners were around $600. My mechanic installed all of this for a flat $180. Once again -- these are not OEM -- these were the FROZEN ROTORS and HAWK pads. Unreal. I can recommend this set up without hesitation - best brakes I've used to date. Wish I had a set up like this back in my IMSA and SCCA days. I'd have been out-braking those pesky 930's into turn nine at Riverside and the corkscrew at Laguna. |
Just curious, you didnt need to change the brake lines or anything other than the rotors and pads right?
2006 M45 Sport - Black on Black - Advanced Tech
msvara
06 M35x
North York ON
5-11-2009
| « Re: (ArbitrageMan) | 10:17 AM 7/21/2009 |
On this note I have a question. I recently replaced the pads on all fours and cleaned everything up nicely. Painted the calipers a fresh silver and used a high temp copper grease on all areas that touch the pads. I am experiencing brake squeal. I then redid the greasing portion and again brake squeal. I just reused the original retainers but there were no shims do I really need the extra shims? The pads are Monroe and come with shims attached.CHEERS!
82 Volvo DL - 300,000kms still goin 98 Cavalier Z24 - Spent too much on modifications! 01 Acura CL-S - 204,000kms Changed the tranny once. 01 VW Beetle Turbo - GARBAGE!!! 07 Cobalt SS/SC - STII 06 Infiniti M35x - Infiniti/Nissan are beautifully made!
jedgington
Cedar Falls IA
8-1-2007
| « Re: (loystock) | 6:03 PM 7/21/2009 |
| Quote, originally posted by loystock » | | So I'm not sure what is the difference. |
Well, I called Joe at IoS today to ask the question and to order the front pads. Evidently, the same brakes fit all models. But, there are two part numbers. The first one is 41060-EG090, and is the $61.33 variety. It seems that this part has been superseded by D1060-EG51A, and is $76.66 [prices are IoS prices]. Either will work. Joe wasn't exactly sure about the difference, or why one is $15 more, but suspected it was a change in suppliers or a change in compound. He still has some of the -EG090 in stock, and they are likely the part # originally fitted to my car, and they're cheaper! So, I ordered a set of those. Thanks to Joe at IoS for helping me out.
loystock
Maxima Moderator
San Jose CA
9-22-2003
| « Re: (jedgington) | 10:37 PM 7/21/2009 |
Joe is DA MAN. He's a parts manager now but is still willing to help anytime he's available. When one of his guys messed up with my 2nd to the last order, he apologized and contacted me personally. Nobody is perfect. My latest order just arrived today, as scheduled.
szhosain
Super Moderator
San Jose CA
7-23-2002
| « Re: (loystock) | 5:58 PM 7/22/2009 |
| Quote, originally posted by loystock » | | Joe is DA MAN. He's a parts manager now but is still willing to help anytime he's available. When one of his guys messed up with my 2nd to the last order, he apologized and contacted me personally. Nobody is perfect. My latest order just arrived today, as scheduled. |
Most Excellent! Unfortunately, mistakes do happen. But it is how people rectify mistakes that makes all the difference!  And, this is the reason why we recommend http://www.everythinginfiniti.com for sure. Joe Tsensky has been a long-time NICO sponsor and helps us out. Z
jedgington
Cedar Falls IA
8-1-2007
| « Re: (szhosain) | 5:18 AM 8/1/2009 |
loystock -Well I replaced the front pads last night. I followed your directions to the letter, along with the pages from the BR section of the manual. It took me about 2 hours to complete. I spent a lot of time cleaning junk from the shims and retainers before regreasing them. I used the CRC brake quiet between the shims and pads. Although I am mechanically-inclined, I've never worked on my car before. I greatly appreciate your walkthrough. The only thing I'd add to your writeup is the brake burnishing procedure described in the service manual. Thanks again!
M45Caliber
Tempe AZ
6-3-2008
| « Re: (ArbitrageMan) | 8:02 AM 8/1/2009 |
AM -- that is correct -- a simple bolt on operation. The rotors are premium stock in the OEM size. Frozen Rotors treats them cyrogenically (sp?) which effectively modifies the characteristics of the alloys from which they are made - significantly hardening them.I took the liberty of painting the calipers as well, to clean up the look. If you search this forum there is a post with "before and after" pics, etc. I may not have that racer-look with slotted and drilled rotors, but I got me some butt-kickin binders that out perform stock by a wide margin and should last about 50 to 75K miles (per their experience). The Hawk pads are also virtually dustless as well. no residue between washings. I was sceptical before taking the plunge on this set up but now, after a couple of thousand miles, I couldn't be happier.
mizzoulew
2007 M35x
Independence MO
11-13-2009
| « Re: (loystock) | 1:02 PM 11/13/2009 |
Hi, loystock. I hope you're still visiting this site. I have a 2007 M35x that I'm replacing the front disc pads and hardware. The AKEBONO ProACT ceramic pads that I bought and the Dorman hardware, are significantly different from my OEM stuff. There are two sets of shims with the Infiniti hardware, plus new caliper brackets for the pads to "slide" in. The Dorman hardware consists of only one curly clip for each pad and I don't understand how that installs or works in this configuration. Also, you recommended lubing between the inner and outer shims on the Infiniti hardware. The AKEBONO shims, only one per pad, are apparently glued or bonded to the disc pad plate from the factory. Should I lube the back of the shim or leave it alone (dry)? There's a small vial of lube in the AKEBONO box, no instructions. Should it be used on the disc plate tabs that slide back and forth inside the caliper hardware?Finally, the Infiniti dealership parts people are telling me that they do NOT install ceramic pads, but semi-metallic. I went ahead and purchased the Infiniti pads because the hardware was so different, I thought I should. When comparing the AKEBONO and Infiniti pads, the Infiniti's are thicker, have two, rather than one, heat slots, and, the pad surface is light brown vs, black on the AKEBONO. I read a thread that said there's a "second generation" pad from the original. These Infiniti pads are part no. D1060 - EG51A, corresponding to a newer pad. Could these be better, possibly ceramic? The Infiniti dealership people say the ceramic pads are harder and will warp the rotors. I've heard just the opposite about metallic and semi-metallic and have installed ceramic pads on my Honda Accord and F-150 - no problems. I thought ceramic pads run cooler and are less abrasive on rotors. Which is right?
