xX RB Xx
Fairlady Z
Memphis TN
6-20-2007
| « Re: just did compression test... wat was urs? mine was... (24j0hn) | 1:49 PM 7/2/2009 |
it could just mean that you need new valve stem seals
24j0hn
91' 240sx with some babying to be given
san dimas california
12-28-2008
| « Re: just did compression test... wat was urs? mine was... (xX RB Xx) | 2:50 PM 7/2/2009 |
yeah... im thinking of just sandblasting the whole damn thing
xX RB Xx
Fairlady Z
Memphis TN
6-20-2007
| « Re: just did compression test... wat was urs? mine was... (24j0hn) | 3:07 PM 7/2/2009 |
please do it.. i want to know what will the result will be
hbpignosePA
90 240sx hatch, 78 Datsun 280z (RIP), 89 cressida (winter beater) 86 200sx hatch (new DD ftw)
York PA
12-1-2006
| « Re: just did compression test... wat was urs? mine was... (xX RB Xx) | 6:24 PM 7/2/2009 |
damn dude are you for real?or are you hear for our rolfcopters?
new project s12 hatch
24j0hn
12-28-2008
| « Re: just did compression test... wat was urs? mine was... (hbpignosePA) | 7:18 PM 7/2/2009 |
i dunno wat that means... but yeah im foreal:)im so happy, cuz i was about to buy a new KA for $200... now i could use dat money for a in the engine bay rebuild... im gunna get a timimg chain from FRsport, a new knock sensor, and get my head machined along w/ valves... then ill need to find where my leak is coming from, reseal the oil pan w/ gasket, and thr in some nismo motor mounts:)  look for a build coming soon!!!
hbpignosePA
York PA
12-1-2006
| « Re: just did compression test... wat was urs? mine was... (24j0hn) | 7:28 PM 7/2/2009 |
sweet ill keep and eye out when i need a good laugh
pandapants
89 DragonWagon
Gainesville/Orlando Fl
3-17-2008
I don't get it.what are you going to sand blast and why?
24j0hn
12-28-2008
| « Re: just did compression test... wat was urs? mine was... (pandapants) | 8:37 PM 7/2/2009 |
im going to get the valves sandblasted so that they sit on the head evenly...
 carbon build up sticks to the seat so that it doesnt sit evenly and im my case its because my valves seals are old and cracked so that i leak and when the oil burns it builds up on the valve... sand blasting is air and trillions of fine crystals be squirted at very high psi braking loose the carbon and making the valve like new... this way i dont need to buy new ones and save $300 you guys make fun of me make fun of me like youve never heard of sand blasting before...
sebazztard
1992 rb25 powered 240sx hatch, 1990 nissan 240sx SE hatch - DD
ny
3-2-2007
| « Re: just did compression test... wat was urs? mine was... (24j0hn) | 9:02 PM 7/2/2009 |
| Quote, originally posted by 24j0hn » | | dat money |
 1992 Nissan 240sx Hachback - Project (rb25det) 1990 Nissan 240sx Hatchback SE - DD need misc s14/s13 5 speed stuff ? http://forums.nicoclub.com/zer...n-abs
Didderson
1990 240sx fastback sr daily.
Harrisburg/Lancaster PA
3-18-2006
| « Re: just did compression test... wat was urs? mine was... (sebazztard) | 9:14 PM 7/2/2009 |
Sand blasting the valves is NOT YOUR PROBLEM at this point buddy.Oil is sliding through where the long rod is on those valves. Called a valve seal. Take the head off and replace em. I did a writeup that didn't get put into the articles section that you may search for. Sandblasting them will help get the carbon off, but may just fuk up their surface so you'll have to re-seat them anyway. Just use goof off or carb cleaner to clean the valves duhhh edit for claro clarity: Your compression is wonderful, which means even IF your valves have soooo much carbon on them (LOL) they're seating and sealing perfectly fine. You're correct the problem is oil coming thru the valves, but it has nothing to do w/ the valve seal seeing as the valves OPEN and thus the oil slides down the shaft and valve and enters. Sry we were all nubs once. I apologize but you acted like you knew exactly what was wrong and you weren't totally right so... Also op, this is the 2nd time I've told you. your sig is filled with annoying nub grammar. the word site is a website, the word sight is the act of seeing.
Modified by Didderson at 9:21 PM 7/2/2009
  Current "Blue Space Shuttle" SR'd 240 | *Lanc blog*
sebazztard
ny
3-2-2007
| « Re: just did compression test... wat was urs? mine was... (Didderson) | 9:32 PM 7/2/2009 |
true dat didderson
24j0hn
12-28-2008
| « Re: just did compression test... wat was urs? mine was... (Didderson) | 10:50 PM 7/2/2009 |
of course im going to put new seals and seats... and here is something i said earlier| Quote, originally posted by 24j0hn » | | valves seals are old and cracked so that i leak | and id rather SEAFOAM
Didderson
3-18-2006
| « Re: just did compression test... wat was urs? mine was... (24j0hn) | 10:09 PM 7/3/2009 |
You don't need new seats for the valves, just seals. Seafoam is great, but because you'll have the valves out your money'd be better spent on carb cleaner because it comes in a spray can. Steel wool it after soaking and you're good to go. Seafoam is better for use if you're not taking the head off because it uses combustion to extract carbon, but it still will do a bangup job without ignition.
OutToWinPAHC
240sx Moderator
Online
1991 240sx Hatch with LS6/T56, 1992 F2
Philadelphia PA
5-31-2007
| « Re: just did compression test... wat was urs? mine was... (Didderson) | 10:29 PM 7/3/2009 |
Just clean thr valves and head and do the seals...... If you don't feel like doing that take your head to a machine shop and have them sonic clean it for you and do the seals.Sandblasting valves....... thats as bad as flushing the dirty oil out with water. Or porting and polishing your head with sand via engine vacuum
2002 F-Body LS6, Port / Polished 243 heads with Patriot Racing dual gold springs, Magic Stick V.3 Cam 237/242 .603/.609 114LSA, 1.7:1 Rockers, TR 7.40 Hardened pushrods, LS7 lifters, Ported LS6 oil pump, Comp Cams timing gear / chain, 37# Racetronix injectors, BBK 80MM TB, T56 Spec stage 3More power then a C6 Z06 in a S13.5
kc240guy
90 champagne coupe
Kansas City mo
6-29-2006
| « Re: just did compression test... wat was urs? mine was... (Didderson) | 11:23 PM 7/3/2009 |
to quote Didderson (Also op, this is the 2nd time I've told you. your sig is filled with annoying nub grammar. the word site is a website, the word sight is the act of seeing.)He could mean this website.... you know, a play on words.
24j0hn
12-28-2008
| « Re: just did compression test... wat was urs? mine was... (kc240guy) | 3:52 PM 7/4/2009 |
i still need to change all my valve seals and get it machined i might as well get the head ported & polished and clean the valves and get the, reseated...
