| Quote, originally posted by MagikDragon » |
| I'm not exactly sure 3 hours is in the cards, What all needs to be done to the car? maybe I can help. |
Oh yeah, NE speed limits are 55 mph! I forgot.Still well worth the 3 hour drive to get a once over and determine which preventative maintenance should be performed. Never underestimate the value of expertise!
Brake job should be able to be done by any ASE certified shop. Get parts from Joe,
http://www.infinitipartsusa.com today for discount
OEM pads, have rotors turned, measure hub runout (lateral and radial), and have a shim kit on hand if you need it.
If you need rotors, I personally like the plated and drilled Stillen Brembo that Je sells. Tirerack has the unplated Brembo but they will rust like stock rotors where they are not scraped by the pad. Do not buy cheap eBay rotors! Or even PoopBoys crap.
