 BRAKE ROTORS?
Biggsam21
2004 ARMADA
GAITHERSBURG MD
3-8-2009
  BRAKE ROTORS?
ARE THE BRAKE ROTORS ON THE NEW ARMADA BIGGER THEN THE OLD ONE? AND IF SO DO THEY FIT THE OLD ONES.
Poyzinous
NICO’s Loco Tech
2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Latitude 38.8 Longitude 77.1
2-2-2009
 « Re: BRAKE ROTORS? (Biggsam21)
Your caps lock button seems to be malfuctioning.
The rotors are different. I dont think they will fit on older ones because the calipers are different and so are the pads. On top of that, the new model has a stronger redesigned hub, further making compatibility less likely.
Quote, originally posted by Poyzinous »
Dude, check out my awesome sig!
Click here for an oil change how-to
My Xbox gamer tag is also Poyzinous
C-Kwik
2004 Nissan Titan LE Crew Cab, 2005 Honda CBR600 F4i
SoCal CA
8-2-2002
Newer Titans and Armadas do have larger rotors. I believe its about 1 inch bigger (close to 14" diameter). I believe it has been done, but will require the rotors and the calipers to make it work. Not sure if the existing brakeline will work or not.
The significant issues that come in my mind though are how the piston sizes compare to the older model brakes. In order for the brake torque ratio to remain the same, they will have had to use smaller pistons in the calipers to reduce some of the clamping force as the rotor diamter is bigger and will provide more brake torque for a given clamping force. Or, the manufacturer would have had to update the master cylinder to compensate or a combination of both.
"Bad Driver's Famous Last Words:
Watch This!
» Return to Armada Forum / QX56 Forum
