How do I achieve 9:1 compression on a VG30DE
Z32FTMFB
Car: 1989 Fairlady Z
Hey, I'm just wondering how to achieve a 9:1 compression on my VG30DE engine. I was told that needed to be done in order to put any turbos onto it.
sdhsbaseball
Car: 1991 300zx TT
You would have to bore the cylinder heads out and put different pistons in the engine and even at that idk if you can get it all the way down to 9:1 and for all that hassle it would be much simpler to do a tt swap
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if you want a turbo your best bet is to sell the n/a and buy a TT, if you must turbo your car you are far better off just buying the ocmplete front cut
if you want to turbo the n/a you still need lots fo parts from the TT (been covered, search) to boost the stok compression you still need larger injectors, and an aftermarket engine managment to allow you to tune the fuel and timing to work with the higher compression without blowing up
save time and money, sell the n/a and buy a TT
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
sdhsbaseball wrote:You would have to bore the cylinder heads out and put different pistons in the engine and even at that idk if you can get it all the way down to 9:1 and for all that hassle it would be much simpler to do a tt swap
The cylinder heads wouldn't need touched. You would only need to buy pistons that are made to have a 9:1 compression ratio. I've seen them made for the DETT so they would fit the DE just fine.
ChefsRedZ
Car: 1990 Nissan 300zx N/A 2+2
balls deep
mtcookson
1992 Iinfiniti Q45
and much much more
If this post and your other similar posts are an attempt to get your post count up to 10 to sell an item, its not going to work.
Just a warning.
