07sportm35 »
https://forums.nicoclub.com/07sportm35-u125434.html
Wed Jul 01, 2009 5:16 am
Just was curious wether or not it would fit. I bought a 20 inch staggered set wich consisted of rear 10 inch wide +43mm offset and front 8.5 inch wide +35mm offset. Front tire 245/35 and rear tire 275/30.
It's interesting to note that the fronts weigh in at 55.5 pounds and the rears weigh in at 59.5 pounds(wheels +tires).
I like the look but would have to buy a new pair of 10 inch wide wheels and 275/30 tires. With a 10 inch wide wheel you need a 275 wide tire otherwise you will be stretched. The great thing about width and size is that they are able to give you more lip.
Rear lip size 4 inches. Front lip size 2.25 inches. The 4 inch lip looks quite a bit nicer. And, it affords you a flush look without a low offset. Remember, factory is +50mm. I personally prefer to stay within 10mm of that.
Like our moderator says, the prefered way to get flush is with a wider wheel.
Ideally I would have forged wheels to get back to around 50 pounds. If I decide to stick with 20's maybe someday...
