stv »
https://forums.nicoclub.com/stv-u133664.html
Mon Jun 29, 2009 12:23 pm
Ok, I dont know who all has been reading my problems, so to make a long story short, my car overheated, cracked the head so I had to get a new/used motor. I patched the crack on my radiator until I get a new one and when I start the vehicle it sounds great, when I give it gas it almost dies or does die, then after a little while after playing with the throttle it will rev up, but if I let it idle and then hit the gas, it goes back to the problem. The only code that was thrown is egr temp sensor, which I replaced and it didnt make a difference, the same code is thrown sometimes, other times the CEL isnt on. The only other code thrown was that my #2 gear (ATX) is not responding, but I doubt that is the case, I believe it is being thrown for another reason. Any thoughts? and my radiator question is, what other vehicles (y,m,m) have the same radiator? Thanks I need help!!! 2000 G20 sr20
